08-28-2007 03:13 AM - edited 03-14-2019 11:15 PM
I currently have two of these MCS-7825-I3 servers. According to this URL:
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/products_data_sheet0900aecd805efb09.html
it is stated that these are servers for 5.1 or 6.0 Cisco Unified Communications Manager Application.
My problem is that my sales team sold a MCS 7825-I3, 1000 User CM4.2-K9-7825-I3 software package which seems to be compatible with the aforementioned servers. Considering this SW, I tried to do the installation with the installation DVDs included in the package. Nothing worked. With Disk 1 (78XX-I1/I2) the hardware detection clearly states that the hardware is not compatible. With Disk 2 (7825-I3, 7845-I1/I2) it begins the installation and then gets to a point where I get a notification that it is "gathering information" and ejects the DVD. Nothing else happens after that point.
Am I looking at this problem with the wrong approach?
Any help would be much appreciated.
cheers,
pedro
08-28-2007 03:26 AM
Pedro,
I have faced the same problem right now. Please, contact your Cisco SE in order to provide you with a BIOS upgrade version. After that upgrade all things work fine.
Hope this helps,
Juan Luis
08-28-2007 03:30 AM
hi lpezj
do u know how the authentication and validation work that this HW is for this CCM SW?
i faced something similar to this previously, HP-DL380-G5 with CCM 5.1 all things were ok, except that the clock rate value was not as that in the documents.
08-28-2007 03:28 AM
Looks like you were shipped OS 2000.4.4 instead of OS 2000.4.5 and that is the reason you are getting the error message. This is a Supported Server for CallManager 4.x. Please check the following link for the list of servers which support OS version 2000.4.5 http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/win_os/rel_note/rn200045.html#wp42549
The most simple thing that you can do is contact the Cisco Reseller/AM/SE from whom you bought the server and check if they have a copy of this version of CD. Incase try dont have a copy handy then you would have to order for the CDs using PUT (http://tools.cisco.com/gct/Upgrade/jsp/index.jsp).
For more info on ordering CDs, please refer AVVID CD FAQ:
Hope this helps
08-28-2007 03:38 AM
Hi mchandak,
thanks for your kind reply.
that's part of my problem. The shipped OS is a 2000.4.5. So, theoretically, I should have no problems installing it. As these installations are pretty straight forward in this preliminary phase of hardware detection I come up with two situations:
either it is detected as a conforming platform or it is not. Unfortunately for me I'm getting the later.
cheers,
pedro
08-28-2007 03:45 AM
Ok, the culprit is CSCsk00441. As mentioned earlier in the thread the issue is with the BIOS version. Please open a TAC case and quote this Bug ID. The TAC Engineer should be able to give you the BIOS upgrade needed as a workaround.
Please check http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk00441 for more details
Hope this helps
08-28-2007 05:56 AM
mchandak,
Thank you for everything. I will open a TAC case asap.
cheers,
pedro
