820
Highlighted
mcs 7825-i4 - raid issue
Hey Guys,
I've rebooted our publisher v8.0.2, and in the show  hardware I get the below. As you can see the state for the 2nd drive is out of sync (OSY) But the state of volume says resyncing... How long does this take? it's been a few hours now?
Many Thanks
ontroller information
Controller type                         : SAS1064E
BIOS version                            : 6.16.00.00
Firmware version                        : 1.26.81.00
Channel description                     : 1 Serial Attached SCSI
Initiator ID                            : 112
Maximum physical devices                : 62
Concurrent commands supported           : 266
Slot                                    : 0
Bus                                     : 1
Device                                  : 0
Function                                : 0
RAID Support                            : Yes
IR Volume information
IR volume 1
Volume ID                               : 1
Status of volume                        : Resyncing (RSY)
RAID level                              : 1
Size (in MB)                            : 237464
Physical hard disks (Target ID)         : 2 3
Physical device information
Initiator at ID #112
Target on ID #2
Device is a Hard disk
Enclosure #                             : 1
Slot #                                  : 1
Target ID                               : 2
State                                   : Online (ONL)
Size (in MB)/(in sectors)               : 238475/488397168
Manufacturer                            : ATA
Model Number                            : WD2502ABYS-23B7A
Firmware Revision                       : 3B04
Serial No                               :
Drive Type                              : SATA
Target on ID #3
Enclosure #                             : 1
Slot #                                  : 0
Target ID                               : 3
State                                   : Out of Sync (OSY)
Manufacturer                            : ATA
Serial No                               :
Drive Type                              : SATA
Enclosure information
Enclosure#                                : 1
Logical ID                              : 5005076b:064c9640
Numslots                                : 4
StartSlot                               : 0
Start TargetID                          : 0
Start Bus                               : 0 of
Content for Community-Ad
Cisco COVID-19 Survey
