02-15-2013 03:49 AM - edited 03-16-2019 03:44 PM
Hi!
I am want to upgrade my MCS-7825H3 server to 4G of RAM so it can support CUCM version 8.
But I cannot find RAM for any MCS-xxxx HP server on Cisco Commerce Workspace and the MCS-7825H3 is
not listed on the "Product Line" selection on Kingstons website.
Anyone who knows exactly where to get these extra 2G RAM modules?
Thanks!
Solved! Go to Solution.
02-15-2013 07:03 AM
We did similar upgradation where in we placed the order to HP directly for extra DRAMs.I think u are using MCS7825H3-IPC1 server.
Your equivalent HP server for MCS 7825 H3 is
DL320-G5 Server
Single Intel 3050 Xeon 2.13-GHz
2GB RAM
2x 160GB Hard Disk
You can also speak to HP and get the PART Codes for RAM.
regds,
aman
02-15-2013 04:03 AM
Please check with Cisco's Partner Helpline team.
By opening a case with Partner helpline (PH) team, please use www.cisco.com/go/ph to do so.
They will be able to assit.
Anand
02-15-2013 07:03 AM
DL320-G5 Server
2GB RAM
2x 160GB Hard Disk
regds,
aman
02-15-2013 07:12 AM
The MCS 7825 H3 is equivalent to an HP DL320-G5 Server
You can get HP or 3rd Party memory upgrades for this; you can no longer get them from Cisco.
Reference:
Barry Hesk
Intrinsic Network Solutions
02-18-2013 11:52 PM
Thanks for the info guys, I will get in touch with HP then!
