10-19-2007 02:15 PM - edited 03-15-2019 06:55 AM
How to setup the system management port in MCS7835-I2 which IBM platform? or URL to refer.
Thanks in advance,
10-25-2007 10:41 AM
System management ports -> RJ-45 for IBM RSA2 dedicated Ethernet port
Try:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/win_os/rel_note/rn200045.html
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/products_data_sheet0900aecd805880c0.html
10-28-2007 06:35 PM
MCS7835-I2 (IBM) has two Ethernet NIC and one system management port. My question is how to configure the system management port which I think analogue to HP's ILO port.
I know how to configure HP iLO. please guide me how to the IBM's system management port in MCS box.
Thanks in advance,
10-29-2007 10:44 AM
I would open a TAC case for that. The support matrix for hardware and software (I think only 5.0 and 6.0) whether you can use it for upgrades (I know you can't use HP's ILO for upgrades for some reason) is weird.
I opened a TAC case for the RSA a year or so ago (can't remember the details) and it gave me a headache, so I told the customer to either use VNC for what they wanted to do or buy an IP KVM switch (some of which may also have issues especially during upgrades.)
I just use VNC for management. The idea sounds nice to be able to see POST, etc, but the real world makes it too complicated to want to use.
12-14-2009 01:56 PM
Did you ever figure this out? I am new to IBM servers and need to know
how to setup the RSA II to obtain ILO like functionality.
Frank
12-14-2009 04:02 PM
So if I understand correctly you want to do something similar to HP iLO with the IBM server. In IBM terminology, this feature is called IBM RSA II Slimline, this their name for remote managerment via IP.
Please refer to the following doc from IBM for info on how to configure and use the RSA on this server.
ftp://ftp.software.ibm.com/systems/support/system_x_pdf/43w7827.pdf
04-11-2010 07:16 PM
Has any one been able to get the remote control feature working?
06-30-2011 01:20 PM
I have exactly the same question. This is for UCM and UXN 8.0
