09-05-2010 01:31 PM - edited 03-16-2019 12:38 AM
The ios command media flow-around seems to be missing in my command set event though the release notes says it should be there. Any one konw whet version it is in. I am on
isco IOS Software, 3800 Software (C3845-IPVOICEK9-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Solved! Go to Solution.
09-22-2013 02:13 AM
You need IPIPGW image i.e. _ivs image. Here is the filename:
c2800nm-adventerprisek9_ivs_li-mz.124-24.T4.bin
Download Link:
I'm quite disappointed with the rating you have provided. The intent was to help and all info I shared was valid and relevant. Anyways, good luck. Your problem will be solved after you follow the above recommendation.
Harmit.
09-05-2010 03:37 PM
I think you need an IP to IP Gw image for that.
02-24-2011 08:27 PM
Hi Michael,
Can u try this?
Router#conf t
Router(config)#voice service voip
Router(conf-voi-serv)#mode border-element
After this do a write mem which will save the configs and reload the router.
Please let me know if we are able to see the flow options.
Abhi.
09-22-2013 12:51 AM
Hi all,
I also have same issue:
Ro_BR2(config)#voice service voip
Ro_BR2(conf-voi-serv)#med
Ro_BR2(conf-voi-serv)#media ?
forking Enable media forking
statistics Media statistics is enabled
Anybody help me?
Thuc
09-22-2013 01:25 AM
A couple of things:
1> You need to configure "allow-connections sip to sip" under "voice service voip" before you can configure media flow-around.
2> Ensure your IOS supports the command and where you would like to configure it. A couple of links to refer to:
HTH.
Harmit.
09-22-2013 01:40 AM
Hi Harmit,
Pls look at my config:
version 12.4
service timestamps debug datetime msec show-timezone year
service timestamps log datetime msec localtime year
service password-encryption
hostname Ro_BR2
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 1000000
enable password 7 045802150C2E6C1F5B4A51
no aaa new-model
memory-size iomem 10
clock timezone VietNam 7
dot11 syslog
ip source-route
ip cef
ip dhcp pool Voice
network 10.30.30.0 255.255.255.0
option 150 ip 10.10.10.3
default-router 10.30.30.1
ip dhcp pool voice
no ip domain lookup
ip multicast-routing
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol cisco
h323
no h225 timeout keepalive
call start interwork
sip
registrar server
voice class media 1
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
Ro_BR2#show ver
Ro_BR2#show version
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 05:38 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Ro_BR2 uptime is 3 days, 2 hours, 53 minutes
System returned to ROM by reload at 12:43:11 VietNam Thu Sep 19 2013
System restarted at 12:44:48 VietNam Thu Sep 19 2013
System image file is "flash:c2800nm-adventerprisek9-mz.124-24.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2821 (revision 53.51) with 237568K/24576K bytes of memory.
Processor board ID FHK0925F38B
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
2 Low-speed serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Ro_BR2#conft
Translating "conft"
Translating "conft"
Translating "conft"
% Bad IP address or host name
% Unknown command or computer name, or unable to find computer address
Ro_BR2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Ro_BR2(config)#voice service voio
Ro_BR2(config-dial-peer)#dial-peer voice 200 voip
Ro_BR2(config-dial-peer)#mde
Ro_BR2(config-dial-peer)#me
Ro_BR2(config-dial-peer)#media ?
% Incomplete command.
I think IOS version is ok . Any idea?
Thuc
09-22-2013 02:13 AM
Download Link:
Harmit.
09-22-2013 02:43 AM
Thanks, Harmit
Thuc
