Mediasense installation problem.
krishnashk
Hi Guys
I wanted to try mediasense in my lab. Tried installing the 8.5.4 on VMware workstation 11 using the ova template from cisco. Installation was fine. But was unable to get the login page. Tried restarting the Cisco Tomcat service. no luck.
Also I am unable to ping the ip address of the media sense server.
During the boot i get mount point  error(attached image).
Tried to run a diagnosis and got error on Tomcat sessions.
Any suggestions?
Thanks in advance.
Manish Gogna
Hi Krishna,
As per the Mediasense design guide for version 8.5(4) "Cisco MediaSense may only be deployed on top of a VMware hypervisor, which must be running on a Cisco B-series server with fiberchannel-attached SAN storage (for at least the first two disks), or a C-series server with directly attached hard disk drives, or a Services-Ready Engine (SRE)."
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/mediasense/854/srnd/cms854srnd.pdf
Manish
Manish Gogna
Hi Krishna,
Manish
Thanks Manish for the response.  Can any other  version  of mediasense be installed in lab(on pc) ?
All the UC products are meant to be used on ESXi, nothing else, you *might* be able to run them on other options, but we have no official support, nor expertise on doing such, depending on what you want to test in your lab, you should be running a supported environment, like the one that the customers are running, you won't find customer running over workstation.
java
if this helps, please rate
Hi Jaime
Yeah I get it.  I was wondering  if we can install mediasense as Cucm and unity on other platform  like workstation.
Thank you.
