Meet Me number config with CCM 7x
kalbasha0
Hello
Current config is ccm 7.1.2 and would like to know to configure meet me number with CCM 7.x from A to Z
any idea it would be greatly appreciated
Thx
Tapan Dutt
Hi Kyle
How the Meet-Me Number is Used
In order to use the Meet-Me feature, go off-hook and press the       Meet-Me button from your phone. Press the       More softkey once in order to reach this Meet-Me. After you       press the Meet-Me button, dial the conference number that you want to join.       Everyone who dials the same Meet-Me number joins the conference together.
For A to Z  information to setup Meet Me  follow the steps in the following link:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b03meet.html
Although this DOC is for CCM 6 but the configuration remains same.
Tapan
Thx for the update, however i'm unable to view the link below perhaps if you could provide me with  detail instruction on how to cofigured meet me number on call manager 7.x .
First step I have created Meet-Me Number/Pattern via Call Routing
If you've already created a meet me DN, that's it. The rest of the config for this to work relies on the fact that you have access to a CFB via the MRGL which you define at device or device pool level and that your CSS reaches the meet me DN partition. If that's already configured then you can go ahead and use them.
Just remove partner/ from the url and you should be able to see the link.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
