Cisco Community Designated VIP Class of 2020
1072
Beginner
Meeting Place 7.0
I received today meeting-place servers contain (Application Server,Media Server,Web Conferencing Server). Could any one has a step by step installation and configuration guide.
Ali Nasser
12 REPLIES 12
Meeting Place 7.0
The documentation available is on the product page (and linked DocWiki in some cases): http://www.cisco.com/en/US/partner/products/sw/ps5664/ps5669/tsd_products_support_series_home.html
If you're a partner there is also a PEC course or two on the topic; just search for MeetingPlace.
Meeting Place 7.0
Hi Ali
this is the link to the cisco doc wiki which has a lot  of useful documents for MP 7
http://docwiki.cisco.com/wiki/Category:Reference_Information_for_Cisco_Unified_MeetingPlace%2C_Release_7.0
keep in mind when you start the setup install and make the basic setup of the application server first then you can integrate the media server after and last think setup the internal and external we servers
Beginner
Meeting Place 7.0
Hi Marwan,
I configure the application server and i did the integration with web server,  i test the web conferencing but i facing one issue the integration eith CUCM i configure as document but i can't dial the meeting place number its give fast busy tone i review the configuration in call manager which is (SIP trunk and the ip assgin is application server, RP,RL,RG,SIP security profile,and extension) all are in the same CSS which has access to the SIP trunk.
Please advise.
Ali Nasser
Re: Meeting Place 7.0
Hi Ali
hav eyou configured the SIP trunk side from Meeting ? also if you have a CUCM cluster make sure in meeting place you put the CUCM tat doig call processing first whcih might be the subsecriber IP ( you can check this from CUCM groups )
also have you registered the media server/blade to the application server ? if not you need to do it first
just include all the IPs of CUCM cluster server and make sure you are using the right SIP port interms of in/out UDP or tcp
Highlighted
Meeting Place 7.0
You can also try running "cptrace -t" on meeting place and make a test call. That will clarify if the call is even hitting MP.
-Atul
Please rate, if this helps !!
Beginner
Hi Atul,
I run this command here what i get
My extension is 2222
and MP extension is 3333
please check below.
08/17 12:33:00.58       P 0      In Call : DID/DNIS 3333, ANI 2222 ==========(1)
08/17 12:33:00.58       P 0      Action : DETERMINEAPP
08/17 12:33:00.58       P 0      Action : GOTOAPP
08/17 12:33:00.58       P 0      Applicat : MEETING DIRECT
08/17 12:33:00.58       P 0      Action : ANSWERCALL
08/17 12:33:14.92       P 1      In Call :  DID/DNIS 3333, ANI 2222 ==========(2)
08/17 12:33:14.92       P 1      Action : DETERMINEAPP
08/17 12:33:14.92       P 1      Action : GOTOAPP
08/17 12:33:14.92       P 1      Applicat : MEETING DIRECT
08/17 12:33:14.92       P 1      Action : ANSWERCALL
08/17 12:33:31.58       P 0      Action : CLEANUPCALL
08/17 12:33:31.58       P 0      Action : USER_SAVEPROFILE
08/17 12:33:31.58      P 0      Action : WRITE OD STATS
08/17 12:33:31.58      P 0      Action : DISCONNECTCALL
Please Advise
Ali Nasser
Beginner
Hi Marwan,
Hope you are doing well,
From the meetingplace i configure the CUCM IP under system configuration------call configuration--------SIP configuration. In SIP configuration
SIP Configuration
Display Name : MeetinPlace
Username : (The phone number with is configure in usage configuration-----Access phone number 1(3333)
SIP domain name (Blank)
SIP Proxy Server 1
Hostname or IP address : CUCM ip address
Port : 5060
Transport : TCP
Is these configuration are correct.
and for the media server please send to me how to configure it under the meetingplace
Please Advise,
Ali Nasser
Meeting Place 7.0
have you integrated the media server with the application server yet ?
also go to System Configuration > Usage Configuration
then access number 1 and this need to be same as the username/number 3333  change this value requres restart
Only accept incoming calls from prox make sure it is NO
also make sure that CUCM use TCP for outgoing SIP calls over this trunk
Beginner
No not yet, i am asking for the steps if you have.
Beginner
Meeting Place 7.0
I'm having the same issue. I have configured everything as above. Verified CUCM routing is fine from DNA.
When i call into Meeting Place i get a fast busy tone.
Then only thing i did different is instaed of using TCP as the transport layer i using UDP. Cause Cisco doc said UDP is recommend. Both is CUCM and Meeting Place is configured for UDP.
This is was i got from the log. It look similiar to the issue here.
02/27 16:03:16.09  P 0       In Call  : DID/DNIS 6395, ANI 6331 ============= (1)
02/27 16:03:16.09  P 0       Action   : DETERMINEAPP
02/27 16:03:16.09  P 0       Action   : GOTOAPP
02/27 16:03:16.09  P 0       Applicat : MEETING DIRECT
02/27 16:03:16.09  P 0       Action   : ANSWERCALL
02/27 16:03:47.10  P 0       Action   : CLEANUPCALL
02/27 16:03:47.10  P 0       Action   : USER_SAVEPROFILE
02/27 16:03:47.10  P 0       Action   : WRITE OD STATS
02/27 16:03:47.10  P 0       Action   : DISCONNECTCALL
Beginner
Meeting Place 7.0
I also notice from CUCM SDI traces,  SIP 503 error coimg from the Meeting Place server:
02/27/2012 17:15:19.006 CCM|//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 335 from 10.9.13.149:[5060]:
SIP/2.0 503 Service Unavailable
From: <6331>;tag=56476da0-74f1-4249-bfee-fa08a0b25000-35172000
To: <6395>;tag=ad66c2b0-0-13c4-594ca2-44ebacab-594ca2
Call-ID: 8fa55c80-f4b149a6-22-8e0d090a@10.9.13.142
CSeq: 101 INVITE
Via: SIP/2.0/UDP 10.9.13.142:5060;branch=z9hG4bKaf7f284a59
Content-Length: 0
Beginner
Meeting Place 7.0
Hi Ali Nasser,
May i know, how you sloved this issue.
I'm have the exact same issue you were facing.
Subash
Content for Community-Ad
FusionCharts will render here
