05-07-2007 10:52 AM - edited 03-14-2019 09:20 PM
Compatibility Matrix indicates the latest MPE isn't compatible with 4.2(3), but is with 4.2(1). This can't be right, does anyone have experience with this?
05-07-2007 12:52 PM
As per the data sheet it is CallManager 4.1 or later, so I's say it is supported. http://www.cisco.com/en/US/products/ps6533/products_data_sheet0900aecd8061fae7.html
Can you mention the link where you found this info ??
05-07-2007 03:11 PM
Just setup a H323 gateway or trunk to MPE and that should take care of it. (Also remember to setup the h323 gateway configuration in MPE).
