12-09-2013 09:30 AM - edited 03-16-2019 08:46 PM
For about the past two weeks our phone system whenever you goto the voicemail system both the menu and messages are stuttering. I cannot seem to pinpoint what is causing the problem. In a previous building we had this issue but it was due to switches being placed on a port. That is not the issue with this new building as everything is one to one. We are using version 8.6
12-09-2013 09:46 AM
Hello Todd,
I would say that only way to isolate it being a CUC issue is doing a packet capture and hear the audio.
1- Using CLI(command line interface) thru a remote connection as i.e Putty of the CUC.
2- This command starts the initiation of gathering packets: utils network capture eth0 count 100000 size all file
Where 'filename' is a random name that you would like to provide; the 'count' is the size of the packets that will be captured.
Once this capture is running you can reproduce the issue and once you finish hold Crtl+C and that will terminate the capture session.
3- The file will be saved in platform/cli/filename.cap
Where 'filename' is a random name that you provided.
4- Gather the packet capture from RTMT (Real Time Monitoring Tool), you can see the screenshot in the link below with further information:
https://supportforums.cisco.com/docs/DOC-11599
Then to hear the packet capture using Wireshark you would open the file and then go to:
Telephony>Rtp> Show all streams> Click on the stream based on the Source and Destination Address> Click Analyze> Player> Decode> Play the file.
If it is not stuttering the issue would be somewhere else and is reaching Unity Connection that way.
|>@|/i|>
12-09-2013 10:44 AM
Wow, I really appreciate the in-depth response. So I was able to play the file back and it is still stuttering in the playback on the wireshark. What would be my next step?
12-12-2013 12:14 PM
Any further ideas what it could be? It seems it is stuttering within the pcap file as well.
