Merge local directories from 2 CME's?
Jason Hamlett
Beginner
Beginner
Company has two 2921's running cme/cue on same network. The medical locations register to one CME, the admin side to the other. Is it possible to have people doing searches in the local directory for eomployee phones to get results from both local directories?
Would it be enabing external directories and pointing to the other CME from the local CME?
Thanks!
JAson
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Jason,
The problem with using the external directory url command is that
it disables the local CME directory;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmedirs.html#wp1015876
You would need to set both sets of users on an external directory and point both CME's to it
or just add the users to each others local directory using the directory command
Cheers!
Rob
Recognize Your Peers
