Message on IP Phone - High Traffic, Try again later
jjcollaguazo
Hi All,
Hopping someone can help, I've setup an H323 GW in Seoul and all outbound ISDN calls work fine except international. I’ve attached the debug output of a successful and failed call (debug isdn q931), also debug voice ccapi inout.
I've confirmed route patterns are valid and CAC/AAR config. I doubt this would be the issue as the call is going out the PSTN not the WAN.
Calls over the WAN work perfectly and I have done some research on the following errors messages i've seen and there's no issue with DSP resources.
Cause i = 0x80AA - Switching equipment congestion
Cause i = 0x80E0 - Mandatory information element missing
I've restarted CUCM (Pub and Sub) and gateway. I've also pushed back to the carrier, but they say it’s not their issue.
Hopefully someone can help.
Cheers
As I wrote in a previous answer, you should ask the Telco about the format that they want to have the calling number for international calls sent to them.
The plan and type I set in the example might not be the correct one, it was merely used as an example. If you don't ask the Telco you'll need to try a few different types and plan until you find the correct one.
If you also want to set the plan and type for called number you can use the same approach as for calling number, so that you don't have that set with a completely different way at a totally different place in IOS. That makes your config more readable and easier to troubleshoot.
Please rate all useful posts.
Response Signature
28 Replies 28
singhaam007
Level 3
Level 3
hello,
here is good article about DSP
http://www.howtonetwork.net/public/1752.cfm
could you please post DSP SIGNALING config from the router
thanks
Hi Amrinder,
Here is the relevant config:
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call preserve limit-media-detection
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711alaw
codec preference 3 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
controller E1 0/0/0
pri-group timeslots 1-31
description *** ISDN 0239965XX ***
interface GigabitEthernet0/1
ip address 10.1.239.2 255.255.255.0
ip pim dense-mode
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.239.2
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn overlap-receiving T302 10000
isdn incoming-voice voice
isdn send-alerting
no cdp enable
voice-port 0/0/0:15
cptone KR
bearer-cap Speech
voice-port 0/1/0
cptone KR
timeouts interdigit 5
timeouts ringing 10
timing hookflash-in 500 150
description *** Main Fax ***
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager music-on-hold
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 10.1.201.10 identifier 1 priority 1 version 6.0
sccp ccm 10.1.201.11 identifier 2 priority 2 version 6.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register TRN00077DCE60D1
associate profile 2 register CFB00077DCE60D1
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 3
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
Read this, DSPs look fine
KOSELVG01#show voice dsp detail
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
edsp 0001 01 g711ulaw  0.1 IDLE  50/0/1.1
edsp 0002 01 g729r8 p  0.1 IDLE  50/0/2.1
edsp 0003 01 g729r8 p  0.1 IDLE  50/0/3.1
edsp 0004 01 g729r8 p  0.1 IDLE  50/0/4.1
edsp 0005 01 g729r8 p  0.1 IDLE  50/0/5.1
edsp 0006 01 g729r8 p  0.1 IDLE  50/0/6.1
edsp 0007 01 g729r8 p  0.1 IDLE  50/0/7.1
edsp 0008 01 g729r8 p  0.1 IDLE  50/0/8.1
edsp 0009 01 g729r8 p  0.1 IDLE  50/0/9.1
edsp 0010 01 g729r8 p  0.1 IDLE  50/0/10.1
edsp 0011 01 g729r8 p  0.1 IDLE  50/0/11.1
edsp 0012 01 g729r8 p  0.1 IDLE  50/0/12.1
edsp 0013 01 g729r8 p  0.1 IDLE  50/0/13.1
edsp 0014 01 g729r8 p  0.1 IDLE  50/0/14.1
edsp 0015 01 g729r8 p  0.1 IDLE  50/0/15.1
edsp 0016 01 g729r8 p  0.1 IDLE  50/0/16.1
edsp 0017 01 g729r8 p  0.1 IDLE  50/0/17.1
edsp 0018 01 g729r8 p  0.1 IDLE  50/0/18.1
edsp 0019 01 g729r8 p  0.1 IDLE  50/0/19.1
edsp 0020 01 g729r8 p  0.1 IDLE  50/0/20.1
edsp 0021 01 g729r8 p  0.1 IDLE  50/0/21.1
edsp 0022 01 g729r8 p  0.1 IDLE  50/0/22.1
edsp 0023 01 g729r8 p  0.1 IDLE  50/0/23.1
edsp 0024 01 g729r8 p  0.1 IDLE  50/0/24.1
edsp 0025 01 g729r8 p  0.1 IDLE  50/0/25.1
edsp 0026 01 g729r8 p  0.1 IDLE  50/0/26.1
edsp 0027 01 g729r8 p  0.1 IDLE  50/0/27.1
edsp 0028 01 g729r8 p  0.1 IDLE  50/0/28.1
edsp 0029 01 g729r8 p  0.1 IDLE  50/0/29.1
edsp 0030 01 g729r8 p  0.1 IDLE  50/0/30.1
edsp 0031 01 g729r8 p  0.1 IDLE  50/0/31.1
edsp 0032 01 g729r8 p  0.1 IDLE  50/0/32.1
edsp 0033 01 g729r8 p  0.1 IDLE  50/0/33.1
edsp 0034 01 g729r8 p  0.1 IDLE  50/0/34.1
edsp 0035 01 g729r8 p  0.1 IDLE  50/0/35.1
edsp 0036 01 g729r8 p  0.1 IDLE  50/0/36.1
edsp 0037 01 g729r8 p  0.1 IDLE  50/0/37.1
edsp 0038 01 g729r8 p  0.1 IDLE  50/0/38.1
edsp 0039 01 g729r8 p  0.1 IDLE  50/0/39.1
edsp 0040 01 g729r8 p  0.1 IDLE  50/0/40.1
edsp 0041 01 g729r8 p  0.1 IDLE  50/0/41.1
edsp 0042 01 g729r8 p  0.1 IDLE  50/0/42.1
edsp 0043 01 g729r8 p  0.1 IDLE  50/0/43.1
edsp 0044 01 g729r8 p  0.1 IDLE  50/0/44.1
edsp 0045 01 g729r8 p  0.1 IDLE  50/0/45.1
edsp 0046 01 g729r8 p  0.1 IDLE  50/0/46.1
edsp 0047 01 g729r8 p  0.1 IDLE  50/0/47.1
edsp 0048 01 g729r8 p  0.1 IDLE  50/0/48.1
edsp 0049 01 g729r8 p  0.1 IDLE  50/0/49.1
edsp 0050 01 g729r8 p  0.1 IDLE  50/0/50.1
edsp 0051 01 g729r8 p  0.1 IDLE  50/0/51.1
edsp 0052 01 g729r8 p  0.1 IDLE  50/0/52.1
edsp 0053 01 g729r8 p  0.1 IDLE  50/0/53.1
edsp 0054 01 g729r8 p  0.1 IDLE  50/0/54.1
edsp 0055 01 g729r8 p  0.1 IDLE  50/0/55.1
edsp 0056 01 g729r8 p  0.1 IDLE  50/0/56.1
edsp 0057 01 g729r8 p  0.1 IDLE  50/0/57.1
edsp 0058 01 g729r8 p  0.1 IDLE  50/0/58.1
edsp 0059 01 g729r8 p  0.1 IDLE  50/0/59.1
edsp 0060 01 g729r8 p  0.1 IDLE  50/0/60.1
edsp 0061 01 g729r8 p  0.1 IDLE  50/0/61.1
edsp 0062 01 g729r8 p  0.1 IDLE  50/0/62.1
edsp 0063 01 g729r8 p  0.1 IDLE  50/0/63.1
edsp 0064 01 g729r8 p  0.1 IDLE  50/0/64.1
edsp 0065 01 g729r8 p  0.1 IDLE  50/0/65.1
edsp 0066 01 g729r8 p  0.1 IDLE  50/0/66.1
edsp 0067 01 g729r8 p  0.1 IDLE  50/0/67.1
edsp 0068 01 g729r8 p  0.1 IDLE  50/0/68.1
edsp 0069 01 g729r8 p  0.1 IDLE  50/0/69.1
edsp 0070 01 g729r8 p  0.1 IDLE  50/0/70.1
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
SP2600 001 01 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 02 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 03 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 04 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 05 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 06 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 07 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 08 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 09 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 10 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 11 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 12 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 13 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 14 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 15 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 16 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 17 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 18 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 19 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 20 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 21 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 22 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 23 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 24 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 25 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 26 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 27 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 28 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 29 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 30 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 31 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 001 32 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 01 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 02 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 03 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 04 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 05 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 06 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 07 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 08 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 09 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 10 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 11 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 12 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 13 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 14 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 15 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 16 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 17 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 18 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 19 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 20 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 21 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 22 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 23 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 24 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 25 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 26 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 27 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 28 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 29 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 30 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 31 None          28.3.1 idle  idle      1  1                 0          0/0
SP2600 007 32 None          28.3.1 idle  idle      1  1                 0          0/0
                           *DSP SIGNALING CHANNELS*
SP2600 007 01 {flex}        28.3.1 alloc idle      1  1 0/1/0     02    0        104/0
SP2600 007 02 {flex}        28.3.1 alloc idle      1  1 0/1/1     02    0        104/0
SP2600 007 03 {flex}        28.3.1 alloc idle      1  1 0/1/2     06    0        101/0
SP2600 007 04 {flex}        28.3.1 alloc idle      1  1 0/1/3     06    0        101/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
KOSELVG01#
Use RTMT to see if you are not facing Call Throttling and the Code Yellow!
See this link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_1_3/ccmfeat/fsclthrt.html
Leonardo Santana
Rate this if helps!
Leonardo Santana
*** Rate All Helpful Responses***
jjcollaguazo
Thanks for the link.
I'll setup RTMT, but I doubt this is the issue as local calls out the GW work every time. CM would see te signalling for a local call and international call the same.
Out of 10 international VGs this is the only new implementation having issue.
I'll report back to see if I have the code yellow.
As suspected its not a code yellow issue. But from an alert i saw could be an exhausted Route List issue. I'll try and delete some route lists to see if it makes a difference.
Removing route patterns made no difference. Removing Seoul specific international patterns cause CM announciator message to say my call can not be completed as dialled.
Any other ideas?
I have also seen this issue with misconfuigred dial-peers, can you post your dial-peers configuration?
Chris
Hi Chris,
Here are the dial-peers. But if something was misconfigured why would other isdn calls work.
voice translation-rule 1
rule 1 /6501/ /9261/
rule 2 /65/ /56/
voice translation-rule 2
rule 1 /^39965/ /56/
voice translation-rule 66
rule 1 /^\([^0].*\)/ /0\1/
rule 2 /^\(0[^0].*\)/ /0\1/
voice translation-profile SRST
translate calling 66
translate called 1
voice translation-profile SRST-VM
translate calling 2
voice translation-profile calling
translate called 1
dial-peer voice 1 pots
voice cut-through alert
description Inbound DID via PSTN
translation-profile incoming calling
incoming called-number .
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 3 pots
description Outbound to PSTN
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0:15
dial-peer voice 10 voip
description Inbound CM-Subscriber Peer
translation-profile outgoing calling
destination-pattern 56..
session target ipv4:10.1.201.11
voice-class codec 1
voice-class h323 1
max-redirects 10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 11 voip
description Inbound CM-Publisher Peer
preference 2
session target ipv4:10.1.201.10
voice-class codec 1
voice-class h323 1
max-redirects 10
no vad
dial-peer voice 66 voip
description Inbound SRST Peer
translation-profile outgoing SRST
preference 3
destination-pattern 39965..
session target ipv4:10.1.239.1
voice-class codec 1
voice-class h323 1
max-redirects 10
no vad
The key thing to note here is that it is not your gateway that is disconnecting the call. The call disconnect is coming from your telco.
I have a hunch something is not quite right on the side of your provider...
I will advise you engage them especially on the congestion message
Sep 22 13:32:53.913: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8093
Sep 22 13:32:53.913: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0093
Sep 22 13:32:53.929: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8093
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Great Point!!!
Its funny how you can miss like that and you start looking everywhere else.
Hopefully i can get contractor to deal with the telco, becuase i don't speak Korean.
Hi All,
The Telco has dones some testing and according to them the reason international calls aren't working, is they only receive the 4 digist extension of the calling device (56XX).
When making local calls the full E164 number is seen and call is successful (0239965XX).
My debug isdn q931 show otherwise though. What could be causing this?
FYI internally the handsets have extension range 56XX and its gets translated to the DID range 0239965XX
jjcollaguazo wrote:
Hi All,
As you wrote it seem that you send the complete calling number, bellow taken from your debug.
Sep 22 13:32:53.797: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0093
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '023996501'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '00161415447000'
Sep 22 13:32:53.881: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8093
But you have both plan and type set to unknown, or probably not set at all in CUCM.
Could you try to set both of these to the desired value of the Telco, what that is you'll have to ask the Telco. A quess would be one of these ISDN/International, ISDN/National or ISDN/Unknown.
Response Signature
