Message Playback Speed Issues - Unity Connection
Abhishek Singh
Hi All,
We have been facing an issue where several users are getting the voicemail playback speeds getting all messed up. Initially we suggested that it might be related to a couple of user's but now everyday we get same issues for hoardes of them.
Issue :
Unity Connection Version : 8.6.2ES44.22900-44
Playback Message Settings  >>>
Message Volume : Medium
Message Speed: Normal
Problem: End  Users do not have access to Cisco Unity Connection . Voicemail speeds even with these settings are slow. We informed them to press from the below mentioned options, which onyl helps for that particular message and particular instance. So in both the cases, issues crops up again. Can this be a bug on this particular version where the playback settings on the GUI page revert to the old one even after making the changes. Appreciate some help on this.
Whatever level you reach getting better never stops -- Sachin Tendulkar
Abhishek Singh
Hi All,
Can someone please guide on this ? Need to get this resolved before the EST sets in today
Hi Abhishek,
what is the Codec u are using ?
regds,
aman
Rob Huffman
Hi Abhishek,
If  you do not want speed and volume changes to be saved as new default  settings for the user, you can disable this functionality by unchecking  the Save Speed and Volume Changes Made by User setting on the;
System Settings > Advanced > Conversation Configuration page in Cisco Unity Connection Administration.
Cheers buddy!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
Thanks Rob.  Let me try that part !
