09-05-2012 04:38 PM - edited 03-16-2019 01:03 PM
I have a a router acting as Mgcp gateway for my CUCM. I would like my CUCM to connect to a SIP PROVIDER using the same router. Is it possible to use 1 router to run both MGCP and SIP. Any examples ???
Solved! Go to Solution.
09-05-2012 05:26 PM
Yes, just configure the MGCP bit and the SIP dial-peers on the same ISR. Follow any regular guide on SIP config as the configurations do not mix. You can even run H323 as well if you want.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-05-2012 05:26 PM
java
