11-20-2010 11:52 AM - edited 03-16-2019 02:02 AM
Hi buddy.
I configure mgcp gateways (routers) with
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager fallback
ccm-manager redundant-host
mgcp
mgcp bind control
mgcp bind media
mgcp call-agent
OK? No problem until here. But when I MUST configure this command? Depends of interface?
ccm-manager config server
dial-peer voice 1 pots
application mgcpapp
port x/x/x:y
Peterson
Solved! Go to Solution.
11-20-2010 01:07 PM
ccm-manager config server - This command allows CallManager to push configuration onto the gateway when you configure the gateway in CallManager. Keep in mind that while you can configure MOST stuff in CCM, you can't do everything over there. But this gives you the ability to do things like reset the gateway via the reset button in the CCM interface. If you don't have this in there, you will need to do a NO MGCP followed by an MGCP to get a full reset.
application mgcpapp
port x/x/x:y
You only need this one on analog ports, and then only if CCM doesn't add it for you (if it does, it will number the dial peer as dial-peer 999XZY where X=slot Y=WIC Z=Port. Sometimes CCM will build this, and sometimes it won't. I've never quite figured out the pattern as to when it does and when it doesn't. You do not need to do this for T1 interfaces, just analog, and then only if CCM doesn't build it out for you.
11-20-2010 01:07 PM
application mgcpapp
port x/x/x:y
