I am trying to configure MGCP controlled gateway but experiencing a call drop issue. A gateway has BRI card installed, when I try to make a call it rings but as soon as I receive call it just drop. I gathered some debug logs (Debug ISDNQ931). I have replaced DSP but still no luck.
When I ring first time after restart Gateway
Oct 31 16:04:23.730: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
2951-rtr1#
Oct 31 16:04:32.423: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2183, '7776137568'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '306892'
Plan:ISDN, Type:Unknown
Oct 31 16:04:32.435: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
Willenhall-2951-rtr1#
Oct 31 16:04:32.463: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
Progress Ind i = 0x8088 - In-band info or appropriate now available
Oct 31 16:04:34.487: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Oct 31 16:04:34.511: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x80AF - Resource unavailable, unspecified
Oct 31 16:04:34.539: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
Oct 31 16:04:34.551: ISDN BR0/1/0 Q931: TX -> STATUS pd = 8 callref = 0x81
Cause i = 0x80E2 - Message not compatible with call state or not implemented
Call State i = 0x0B
Oct 31 16:04:34.703: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8 callref = 0x01
Oct 31 16:04:34.707: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
When I ring second time, it just beep and give this error message
Oct 31 16:05:40.233: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Oct 31 16:05:44.225: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
Oct 31 16:05:48.194: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Cause i = 0x82E6 - Recovery on timer expiry
Oct 31 16:05:48.198: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Cause i = 0x80D1 - Invalid call reference value
This above line Indicates that gateway have no idea what to do with the call.
Have you setup gateway in CUCM ??
Do you configure dial peer point to the CUCM..??
It's a MGCP contolled VGW, so no dial peer would be needed.
Can you post the output from sh inventory, sh isdn status and sh ccm-manager. Also post a print screen on how the gateway is setup in CUCM.
If you also post your running config it will help us to help you.
Please remember to rate helpful responses and identify helpful or correct answers.
Thanks for your reply, I have attached config files and screenshots. Please have a look
Muhammad,
In my experience resource unavailable usually point to a dsp failure...Your gateway is registered so your mgcp gateway config is fine..
Please send the ff:
show voice dsp voice
show voice dsp group all
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Aokanlawon@ I have attached sh dsp.txt. Just wanted to update you I have already replaced DSP but no luck
OK..
The dsp looks fine but I dont see any voice channels allocated...
Signaling channels allocated: 12
Voice channels allocated: 0
Can you send cucm traces?
Aokanlawon@ from cucm what traces you want I mean cisco tomcat cisco trace collection etc
Aokanlawon@ When I ring on DDI number I can see voice channel been allocated, please see below. However as soon as I answer the call it gives a busy tone and disconnect.
Weird thing is when I retry number it doesnt allocate voice channel and kept showing 0 value unless reset BRI interface, ANY IDEA?
Willenhall-2951-rtr1#sh voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x1C 121A 0x12AA3CA4 0/1/0.0 0/1:1 * g711ulaw 0/0
1 active call found
Willenhall-2951-rtr1#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 26.3.8
Max signal/voice channel: 32/32
Max credits: 480
num_of_sig_chnls_allocated: 12
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 465, reserved credits: 0
Voice channels allocated: 1
Credits used (rounded-up): 15
Voice channels:
Ch01: voice port: 0/1/0.0, codec: g711ulaw, credits allocated: 15
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
After answer the call output of the sh voice dsp group all is
dsp 1:
Max credits: 480
Shared credits: 480, reserved credits: 0
Credits used (rounded-up): 0
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 7:
Max signal/voice channel: 16/16
Max credits: 240
num_of_sig_chnls_allocated: 0
Shared credits: 240, reserved credits: 0
Signaling channels allocated: 0
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
DSP groups on slot 3:
This command is not applicable to slot 3
DSP groups on slot 4:
This command is not applicable to slot 4
0 DSP resource allocation failure
What IOS are you running?
I was asking for CUCM SDI traces not tomcat traces...
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 18:58 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Can you please tell me what specific logs shall I download instead of full SDI, then it may reduce the size. I am downloading logs through RTMT and we have several nodes
First of all, you need to know the server the IP phone you are using for test is regiustered to.
Then you need to ensure that the trace settings on the server is set to detailed
Next do a test call, then use RTMT to collect the trace on the specific server for the time range that you made the call..Make sure its the SDI trace you collect..send it over.
Please check the trace before sending it that the calle and calling number is in the trace file and also send the called and calling number
Aokanlawon: I have managed to get SDI traces, please see attached file SDI.zip. Called party number is 638094, sorry cannot provide you calling number as telco blocked CLI. Looking forward to your reply
