Community Helping Community
885
Highlighted
Beginner
MGCP converting IP to FQDN
Hello all, recently when deploying MGCP gateways we have found that after upgrading call manager to version 11 when we configure the "ccm-manager redundant-host" & "mgcp call-agent" are changed from ip addresses to FQDN as soon as the gateway reaches out to CUCM. Does anyone have any information on this behavior change, is this a setting that can be changed?
7 REPLIES 7
How are the servers defined
How are the servers defined in CM Administration under System  >> Server.
Deepak
Beginner
as FQDN per SRND.
as FQDN per SRND.
Rising star
Pls check if a domain name is
Pls check if a domain name is configured on the MGCP gateway, the domain name for the gateway configuration on CUCM must be the same.
Suresh
Beginner
Yes the domain name is
Yes the domain name is configured.
I believe everyone is missing my question. I am not having a problem getting the gateway to register.I am trying to determine if it's possible to prevent cucm from updating the MGCP configuration to using the FQDN and maintain the ip addresses in the gateway configuration.
I want to do this because for registration with FQDN's to work we have had to enable ip domain lookup which we like to keep off so that you don't have to wait for the time out after a fat finger of a command.
Beginner
MGCP Registration rewriting IP to FQDN
Hi Jacob,
I'm experiencing the same thing.  Migrating from CUCM 8.6 to 11.5 the MGCP registration process is overwriting the mgcp call-agent ip defined to the FQDN that is in CUCM System>Server.  Since ip domain lookup is disabled on the gateway the registration fails.
Original Command
mgcp call-agent 10.10.10.10 2427 service-type mgcp version 0.1
Command Observed in IOS
mgcp call-agent sub01.company.com 2427 service-type mgcp version 0.1
VGW#show ccm-manager
MGCP Domain Name: VGW.company.com
Priority        Status                   Host
Primary         Domain Name Unresolvable sub01.company.com
Gateway is a 2901 with IOS is 155-3.M5.
The only resolution I've found is putting the configuration in a second time, again with IP's and it works.
This is not observed with SCCP, limited to the MGCP portion (referencing IP's) of the IOS config and only on the initial 8.6 to 11.5 migration.
ccm-manager redundant-host 10.10.10.11 10.10.10.12
Beginner
Re: MGCP Registration rewriting IP to FQDN
Did you happen to get a resolution to this issue? I'm currently going through the same problem and looking for a solution.
thanks.
Rising star
This is expected behavior when servers are called out by fqdn
Content for Community-Ad
FusionCharts will render here
