05-19-2015 11:46 AM - edited 03-18-2019 11:32 AM
i faced an issue today with an MGCP gateway i tried number expansion translation and transformation but nothing worked to manipulate the incoming called number.
My scenario
PRI -- MGCP(GW) -- Phone with forward all to VM just for testing
PSTN sends 4814
i tried to translate it to 000666 using VGW css and a translation pattern hits the user VM
i tried Incoming called party transformation still goes to the user VM
number expansion on the VGW CLI still goes to user VM
- See more at: https://supportforums.cisco.com/discussion/12488346/digit-manipulation-cucm-mgcp-gateway#comment-10511066
05-19-2015 01:38 PM
This is MGCP, why would you use H.323 configuration?????
ALL CALL ROUTING HAS TO BE DONE IN CUCM!!!
Configure a TP matching 4814 and translate to whatever you want, it's as simple as that.
05-19-2015 02:25 PM
I agree on the fact that this is MGCP!!!
Now its a production environment. I have tried the translation pattern but still it just goes to the user VM.
I will try and see how the digit analyzer will react to this tomorrow.
05-19-2015 02:28 PM
Debug your GW to make sure that you're indeed getting the digits you think, and then it's all CUCM routing, make sure there is no best match and that the inbound CSS reaches your TP, that's all you need to have.
05-21-2015 02:50 PM
no mgcp
mgcp
fixed the problem as the changes was not taking affect.
