MGCP does not show as registered on Callmanager Endpoints
ed.crawford
I have configured a 2911 router to use MGCP with Callmanager 8.5. A show ccm-manager on the router shows that it is registered with the Callmanager as does show mgcp, however under the endpoints for the gateway it shows Unregistered.  Is this because I have not plugged the ISDN into the router yet?
show ccm-manager
MGCP Domain Name: NGHA-RH-RTR-01
Priority        Status                   Host
Primary         Registered               10.100.1.20
First Backup    None
Second Backup   None
Current active Call Manager:    10.100.1.20
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            12:10:19 UTC Mar 9 2011 (elapsed time: 00:00:05)
Last MGCP traffic time:         12:10:19 UTC Mar 9 2011 (elapsed time: 00:00:05)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
    Link Protocol:      TCP
    Remote Port Number: 2428
    Remote IP Address:  10.100.1.20
    Current Link State: OPEN
    Statistics:
        Packets recvd:   0
        Recv failures:   0
        Packets xmitted: 0
        Xmit failures:   0
    PRI Ports being backhauled:
        Slot 0, VIC 0, port 0
FAX mode: cisco
NGHA-RH-RTR-01#show mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 10.100.1.20 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay voip codec all mode out-of-band
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
--More--
NGHA-RH-RTR-01#show mgcp end
Interface E1 0/0/0
             ENDPOINT-NAME    V-PORT     SIG-TYPE   ADMIN
  S0/SU0/ds1-0/1@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/2@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/3@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/4@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/5@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/6@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/7@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/8@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/9@NGHA-RH-RT  0/0/0:15        none   up
  S0/SU0/ds1-0/10@NGHA-RH-R  0/0/0:15        none   up
  S0/SU0/ds1-0/11@NGHA-RH-R  0/0/0:15        none   up
  S0/SU0/ds1-0/12@NGHA-RH-R  0/0/0:15        none   up
  S0/SU0/ds1-0/13@NGHA-RH-R  0/0/0:15        none   up
  S0/SU0/ds1-0/14@NGHA-RH-R  0/0/0:15        none   up
  S0/SU0/ds1-0/15@NGHA-RH-R  0/0/0:15        none   up
15 Replies 15
Rob Huffman
Hi Ed,
This is the expected behavior. Once you have your cct. up and running
the endpoints will transition into a "Registered" state
Cheers!
Rob
Great.  Thanks Rob.
I have same situation, what tou mean when you say "cct. up and running" ?
Thank you very much.
gius
Hi Giuseppe,
How do the endpoints  show in the cucm?
can you please post the output of a show isdn status and a show ccm-manager?
Also a show run | s domain
Carlo
Please rate all helpful posts "The more you help the more you learn"
Dear Carlo,
attached "show ccm-manager", regarding isdn status, we have not yet connected voicegateway to ISDN PRI involved, we are going to do so in the day of migration.
Of course before doing the migration I would like be sure that system has been correctly set up.
Thank you for your kind support.
Giuseppe
Hi Giuseppe,
Until the ISDN layer 2 is not up, you won’t see the up status on the
endpoints.
Carlo
It means that endpoints are displaied as unregistered on CUCM ?
See screen capture attached.
couls you delete the previous attached file please and consider this one.
Could you delete the previous attached file please and consider this one ?
Sorry about that.
hi,
you can also try Tx and Rx pairs physically short that is 1 with 4 and 2  with 5 to check the status of MGCP registration on Call manager
regds,
aman
Thank you Aman,
this is very interesting and usefull.
Refards.
Giuseppe
That’s correct Giuseppe.
Until the show  isdn status doesn’t show Multipleframe established, they will stay in unregistered status.
Carlo
Thank you Carlo,
this is very helpfull.
Giuseppe
Glad to help Giuseppe.
This time is the student that suggests something to the teacher ;)
#ccnpcourse2006
Ciao
Carlo
