03-09-2011 04:12 AM - edited 03-16-2019 03:52 AM
I have configured a 2911 router to use MGCP with Callmanager 8.5. A show ccm-manager on the router shows that it is registered with the Callmanager as does show mgcp, however under the endpoints for the gateway it shows Unregistered. Is this because I have not plugged the ISDN into the router yet?
show ccm-manager
MGCP Domain Name: NGHA-RH-RTR-01
Priority Status Host
Primary Registered 10.100.1.20
First Backup None
Second Backup None
Current active Call Manager: 10.100.1.20
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 12:10:19 UTC Mar 9 2011 (elapsed time: 00:00:05)
Last MGCP traffic time: 12:10:19 UTC Mar 9 2011 (elapsed time: 00:00:05)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.100.1.20
Current Link State: OPEN
Statistics:
Packets recvd: 0
Recv failures: 0
Packets xmitted: 0
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 0, port 0
FAX mode: cisco
NGHA-RH-RTR-01#show mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 10.100.1.20 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay voip codec all mode out-of-band
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
--More--
NGHA-RH-RTR-01#show mgcp end
Interface E1 0/0/0
ENDPOINT-NAME V-PORT SIG-TYPE ADMIN
S0/SU0/ds1-0/1@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/2@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/3@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/4@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/5@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/6@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/7@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/8@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/9@NGHA-RH-RT 0/0/0:15 none up
S0/SU0/ds1-0/10@NGHA-RH-R 0/0/0:15 none up
S0/SU0/ds1-0/11@NGHA-RH-R 0/0/0:15 none up
S0/SU0/ds1-0/12@NGHA-RH-R 0/0/0:15 none up
S0/SU0/ds1-0/13@NGHA-RH-R 0/0/0:15 none up
S0/SU0/ds1-0/14@NGHA-RH-R 0/0/0:15 none up
S0/SU0/ds1-0/15@NGHA-RH-R 0/0/0:15 none up
05-18-2019 04:34 AM
