MGCP fractional PRI to full PRI
David Perez
Hello NetPro,
What are the commands needed to change an existing fractional mgcp pri only using 1-4,24 , to a full pri using 1-23,24. ?
I believe i need to first shut down the controller,
Conf t , controller t1 0/2/0, shutdown
then commands :
no pri-group timeslots 1-4,24 service mgcp
then
pri-group timeslots 1-23 service mgcp.
once thats done, then do command
Conf t , controller t1 0/2/0, no shutdown
then
NO mgcp
Mgcp
Is this correct ? am i missing anything ? do i need to turn off  interface Serial0/2/0:23 also ?
Thank you in advance
5 Replies 5
Turn off also the Serial and the voice-port 0/2/0:23
the you should be fine.
Please Kudos/rate if this help!
Chris Deren
First of all partial PRI was never supported with MGCP, with that said your steps are accurate, plus there are service parameters on CUCM that need to be adjusted, don't recall the names out of top of my head.
Chris
Chris Deren
The parameters are:
Change B-Channel Maintenance Status
with full PRI they should be blank, they are under service parameters -> CUCM -> Device-PRI and MGCP GW
Chris
These settings are blank. We also have 2 other full pri's terminating on this gateway.
Even the partial pri works fine, just only 4 channels and we want to use the entire pri.
thanks Chirs
OK, then just change the controller to have pri-timeslots 1-24 and that's it.
HTH, please rate all useful posts!
Chris
