MGCP FXO Does Not Register With CUCM On VG204XM
mburrell5
I have a VG204XM running MGCP with CUCM 10.5. When the port is changed and reset on CUCM the config pushed down to the VG204XM has an error (this is identical to Bug CSCtr78616 reported on a 28xx router in 2011)
In the logs, I can see that once the router gets the config it tried to configure AALN/S0//0 (voice-port 0/0)
However for some reason it looks like the router is converting the port to a 65535 instead of 0
"cmapp_xml_get_interface_info: slot = 0 vic = 65535 port = 0"
Since the above port does not exist on the router the attempt throws an error.
Mar 27 18:07:59.278: %SYS-5-CONFIG_I: Configured from console by console
Mar 27 18:07:59.278: cmapp_xml_get_interface_info:
Mar 27 18:07:59.278:  ================================
Mar 27 18:07:59.278: cmapp_xml_get_interface_info: slot = 0 vic = 65535 port = 0
Mar 27 18:07:59.278:  Interface_name: AALN/S0/0
Mar 27 18:07:59.278:  controller:
Mar 27 18:07:59.278:  addr: 0/65535/0
Mar 27 18:07:59.278:  interface:
Mar 27 18:07:59.278:  voice_port: voice-port 0/65535/0
Mar 27 18:07:59.278:  dial_peer: dial-peer voice 9990655350
Mar 27 18:07:59.278:  dial_peer_port: 0/65535/0
Mar 27 18:07:59.278: cmapp_xml_configure_router: Checking for Deleted interfaces
Mar 27 18:07:59.278: cmapp_xml_get_intf: Searching for vdb for [0/65535/0]
Mar 27 18:07:59.278: cmapp_xml_configure_router: Analog ports are ready
Mar 27 18:07:59.278: cmapp_xml_find_corr_intf_cfg:
Mar 27 18:07:59.278: cmapp_xml_find_corr_intf_cfg: old_cfg is NULL
Mar 27 18:07:59.282: cmapp_xml_intf_cfg_changed:
Mar 27 18:07:59.282: Old intf config is NULL
Mar 27 18:07:59.282: cmapp_xml_cfg_analog_intf:
Mar 27 18:07:59.282: cmapp_mgcp_get_card_type_for_analog_intf: Searching for vdb for [0/65535/0]
Mar 27 18:07:59.294:    cmapp_xml_cfg_router_intf: configuring intf:[voice-port 0/65535/0]
Mar 27 18:07:59.294:    cmapp_xml_cfg_router_intf: configuring      [echo-cancel enable]
Mar 27 18:07:59.298: %SYS-5-CONFIG_I: Configured from console by console
Mar 27 18:07:59.298: cmapp_xml_cfg_router_intf: error configuring router line 395
Mar 27 18:07:59.298: cmapp_xml_send_msg_to_callmgr: Sending CMBH_MSG_CFG_ERR
Mar 27 18:07:59.298: **** ERROR info: Router configuration failed:voice-port 0/65535/0
 echo-cancel enable
end
I have VG224 gateways running with MGCP on CUCM 10.5 and no errors
Has anyone else experienced this issue on VG204XM?
Manish Gogna
Please check
https://tools.cisco.com/bugsearch/bug/CSCui83022/?reffering_site=dumpcr
MGCP auto config fails for VG204XM
CSCui83022
Symptom:
MGCP auto config fails on VG204XM.
Conditions:
Issue is seen when using auto config using "ccm-manager config"
Workaround:
Remove the autoconfig command from VG204 and configure the MGCP dial-peers manually.
You can upgrade the IOS to one of the fixed versions.
Manish
Manish Gogna
Please check
CSCui83022
Symptom:
Conditions:
Workaround:
Manish
Thanks Manish Gogna, IOS upgrade fixed it!
Thanks for updating the post.
Manish
adil.nasser3
Would you be able to share an example VG204XM configuration using MGCP so I can use as a template to configure ours?
