I have an environment with two CallManagers in a cluster (Publisher 192.168.96.10 and Subscriber 192.168.96.11) and a 2851 as MGCP gateway. All the devices using as primary CallManager the Subscriber and registered to it. The MGCP gateway can't register to the Primary CallManager which is the Subscriber and only registers to the Backup which is the Publisher.
CENTRAL-VG#sh ccm-manager
MGCP Domain Name: CENTRAL-VG
Priority Status Host
Primary Down 192.168.96.11
First Backup Registered 192.168.96.10
Second Backup None
This has as a result, that in case the Publisher goes down, all the internal calls are working properly, but all the outgoing and incoming calls are not working.
Thanks in advance.
Agelos
