08-02-2011 01:40 AM - edited 03-16-2019 06:15 AM
*Aug 2 08:32:09.291: //-1/xxxxxxxxxxxx/MGCP/mgcp_check_hostname(8901):[lvl=0]Trying to validate endpoint name
08-02-2011 02:20 AM
Have you maybe got any dns settings or domain name settings configured? Also you might want to do a debug on the mgcp events spefically looking at the tftp download as it might be looking for a wrongly named tftp settings file.
08-02-2011 04:45 AM
Can you check whether 'mgcp validate domain-name' command is there under 'mgcp' configuration on the router.
If it is present, can you issue 'no mgcp validate domain-name' command under 'mgcp' configuration on the
router ?
