Beginner
mgcp gateway with fxs issue
hi
i have cisco 2921 gateway configured on cucm 11 with MGCP protocol and i have fxs ports
the ports are registred on cucm and the outbound calls from fxs are perfect
i have two probelm concerning inbound call to fxs :
the call is answred even the ip phone not answered yet
i make serveral test of inbound calls some of the theme are disctonnected even i didnt end the call
please find in the attched file the configuration on the FXO  on cucm
this is the configuration on the router :
ip address trusted list
ipv4 10.0.102.0 255.255.255.0
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
session transport tcp
registrar server
license udi pid CISCO2901/K9 sn FGL201920MH
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.0.102.20 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
cptone FR
voice-port 0/1/0
supervisory disconnect anytone
cptone FR
timing hookflash-out 50
timing guard-out 1000
impedance complex2
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
6 REPLIES 6
Could you please try
Could you please try collecting below debugs for incoming call. I suspect some missing config or timer parameters.
Debug voip vtsp all
debug vpm signal
debug voice ccapi inout
Beginner
HI
HI
thanatos for your reply
please find in the attched file the debugs
regards
Beginner
any hepl please about my
any hepl please about my problem ??
Beginner
When you create the MGCP port
When you create the MGCP port in CUCM and it asks you to pick POTS, Loop Start, or Ground Start, choose POTS. Then add the 1001 DN to it.
Edit: Actually, it seems the problem is with an FXO, not FXS port. Disregard.
Beginner
hi
hi
i didn't find POTS on fxo port , juste loop start or ground
when i choose ground the call still desconnect after 4 seconds
i'm using cucm version 11
regards
Highlighted
i was unable to understand
i was unable to understand what you meant by " the call is answred even the ip phone not answered yet". so just looked in logs for call disconnection during the call.
looking at the call legs 47 , it seems disconnection is happening from incoming leg from cucm.
Content for Community-Ad
July's Community Spotlight Awards
