MGCP gateway
pcromwell
Level 3
Level 3
I am configuring mgcp gateway (2911) to a callmanager 8.0.
It is T1 using pri net5 switch type.
When I go onto callmanager ,  on the main screen for the gateway I can only choose euro or australia switch type and when go into port config here is no option for pri net5. Is their an equivalent I need to use
If you are using CUCM 8.0, the following Cisco IOS MGCP gateways are supported. Once if you get the following Gateways as drop-down, choose one and then
you can able to configure the switch-type.  My understanding is 2911 is not supported in CUCM 8.0.
Adding a Cisco IOS MGCP Gateway
Use the following procedure to add and configure a Cisco IOS MGCP gateway to Cisco Unified Communications Manager. The following Cisco IOS gateways support MGCP:
CiscoVG200 Voice Gateway
VG224 Gateway
Cisco IOS 362x, 364x, 366x Gateways
Cisco IOS 3725 and 3745 Gateways
Cisco IOS 26xx and 269x Gateways
Cisco 2801, 2811, 2821, 2851, 3825, 3845 Gateways
Cisco Catalyst 4000 Access Gateway Module
Cisco Catalyst 4224 Voice Gateway Switch
Communication Media Module
Cisco IAD2400 gateways
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_1/ccmcfg/b06gtway.html#wp1646962
You may stuck bcoz of the Gateway selection. Once your Gateway configuration is done, then i think you can do your ISDN Switch-type configuration aswell.
Here's the link for ISDN Switch-type support in CUCM 8.0
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_1/ccmcfg/b06gtway.html#wp1641599
Thanks.
