08-16-2011 08:58 PM - edited 03-16-2019 06:31 AM
Customer has 3 sites, 3 CUCM servers and 1 unity cxn server. The 2 CUCM servers are at the remote sites with the pub / unity cxn server is at the main site. Not my design, just trying to resolve the issue with the failover in a WAN failure. All auto attendants reside on unity cxn of course. I'm trying to get the calls to route over PSTN in the event of a WAN failure but not succeeding. I thought that by removing the MGCP failover commands so that when the WAN fails the h323 commands would take over on the router would work but they do not. Any one have any suggestions on what I could do in order to get this work properly.
08-16-2011 09:56 PM
if th eGW configured in CM as MGCP
and also the H323 dialpeers configured with ccallmanager-fallback enabled (SRST)
then once callmanager is not reachable by the phones they will use the CUCM SRST settings/refernce to register to the GW then it will be operating as SRST/H323 VGW
08-16-2011 10:07 PM
08-17-2011 04:46 AM
That link might work, I have all the h323 dial-peers already configured on the router, problem is that the router is just a voice gateway and does not have the licenses for SRST and the phones never go into fallback since the CUCM server that they are registered to is located at their site not the main site.
08-17-2011 05:16 AM
Christopher,
Trying to summarise this set up
SITE A:-
Phones
2 xSUB CUCM
SITE B any Phones ?
PUB CUCM
UNITY CONNS
Which sites have the gateways ?
Alex
08-17-2011 05:21 AM
then why you need the fallback in this case if you have the CUCM located with the phones and VGW ?
08-17-2011 12:35 PM
Here is the layout.
Site A - Main (phones, gateway, Unity Cxn, Pub)
Site B - Phones, gateway (voice bundle, not SRST bundle) and Sub
Site C - Phones, gateway (voice bundle, not SRST bundle) and Sub
Site B and C have AA on the Unity server. When a wan failure occurs, I'm trying to route the call over the PSTN so that the call in user still hears the AA or if I could just get the call to route to the receptionist at the remote sites and bypass the AA in a WAN failure that would be fine too
They also have a Site D with phones and an SRST gateway and this scenario works great with no problems, have the gateway configured as MGCP and callmanager-fallback and all works as expected. The remote sites not having the SRST feature set as well as having a Sub is throwing a wrench in this scenario.
08-17-2011 09:33 PM
I was able to get this to work, after further testing. i was able to route to the call to an 1800 number during failover, the site where i was calling needed an LD code so this scenario might have been working during my initial testing. Thanks for the suggestions though.
08-17-2011 11:29 PM
how you get it working ?
if in each site there is a CUCM ad if the wan link is down the GW and phones will still use the local CUCM for call routing not sure could you please explain your solutions
08-18-2011 04:59 AM
Within my MGCP configuration I put the IP address of the Pub and I configured no redundant hosts within the configuration. I then have a spare DID at the main location where I configured it to translate to the AA for the remote site. On the remote site router I used the num-exp command to translate the main number to this spare DID over the PSTN. Phones are still registered to the local CM server so no failover on the phones, just MGCP failover on the gateway.
08-18-2011 05:22 AM
nice work around 5+
08-18-2011 05:45 AM
Christopher
Excellent work 5 ++
