05-21-2018 03:06 AM - edited 03-18-2019 12:25 PM
we are replacing 2800 Voice gateway with New 4321 VGW..
where we are facing issue with new 4321 VGw MGCP connection with CUCM (10.5 version)
attached is the old 2800 & new 4321 voice gateway configuration
PRI shows UP & running on new 4321 series router ...but MGCP gateway not registering
Solved! Go to Solution.
05-22-2018 04:08 AM
Right. So as I said, if TAC does not have a 'patch' for your version of CUCM I think you will have to upgrade to a supported version for the gateway to register regardless of the router config.
05-21-2018 05:42 AM
You might be hitting this defect:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuo85914/?rfs=iqvred
05-21-2018 06:12 AM
Hi Vijay,
can u post the output of commands :
a. show ccm-manager hosts
b. show controllers E1 [Do clear counters before capturing the output]
regds,
aman
05-21-2018 09:30 PM
Hello gmgarrian,
Yes found the this Cisco bug..when we tried to configure new MGCP we are not able to see the 4321 in the list .
05-21-2018 06:10 AM
05-21-2018 09:04 PM - edited 05-21-2018 09:05 PM
Hi Vijay,
I do not see the configuration attached with this post. There is only one screenshot which has two Cisco 2821 MGCP Gateway configured.
Can you please attach both router configurations and another screenshot with Cisco 4321 Router configured as MGCP Gateway?
05-21-2018 09:27 PM
05-22-2018 02:39 AM
05-22-2018 03:32 AM
Hello Nipun,
That port is actually in no shut mode...& sh ISDN status give ..PRI UP output
05-22-2018 03:29 AM
The screenshot you posted shows the router configured as a 2821 in CUCM.The 4321 will not register (unless there is some magic I am unaware of) in your CUCM unless it is built as a 4321 in CUCM, regardless of the configuration on the router.
Can you contact TAC to see if there is a patch file that will add support for the 4321 for your version of CUCM? If not, it seems to me that you will have to upgrade your cluster to one of the versions listed in the bug as a 'fixed' version to add support for this router model.
05-22-2018 03:46 AM
Hello Maren,
It absolute right that i need to create a new MGCP gateway with the Gateway Type "4321"
But unfortunately CUCM we are running is of
System version: 10.5.1.10000-7 which is affected with bug CSCuo85914...for which need to apply patch on it ...like
10.5(2.10000.5)
10.5(1.98000.77)
10.5(1.98000.29)
05-22-2018 04:08 AM
05-22-2018 06:05 AM
