1434
Highlighted
Enthusiast
MGCP or H323??
I have 3 sites connected to one main site (all using cme).Main site has 12 FXO Ports. Now i want to connect that main site with our HQ CUCM. Which protocol do i need to use? and why any idea???
1 ACCEPTED SOLUTION
Highlighted
It is not done adding interfaces, but dial-peers.
It is a normal configuration.
You should not ever use MGCP.
14 REPLIES 14
Highlighted
Contributor
You have not mentioned any details with regards to main site. Are you connecting another CME from main site or a Voice GW?
If I presume a Voice GW at main site, you can utilize MGCP if you would like to have complete control from CUCM (HQ).
Regrds...
-Ashok.
With best regards...
Ashok
Highlighted
Main site is running CME itself. sO it has already one h323 interface. I dont think so that i can add two h323 interaces in one router one for local phones and other for CUCM ?
Highlighted
Highlighted
Can you please give me a clue or example of what type of Dial-peer we require without binding the virtual interface via using h323???
Highlighted
Something like this should work:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
dial-peer voice 101 voip
description CallManager Publisher
preference 2
destination-pattern 1...
voice-class codec 1
session target ipv4:10.1.1.1
dtmf-relay h245-alphanumeric
dial-peer voice 102 voip
description CallManager Subscriber
preference 1
voice-class codec 1
session target ipv4:10.1.1.2
It assmumes that you have two CUCM servers - a Publisher with IP address 10.1.1.1, a Subscriber 10.1.1.2 - and that the CallManager extensions are four digits starting with a 1.
Highlighted
thnx v much for your info.
I just googled and came to know that in order to h323 protocol on gateway, we dont need the h323-gateway voip interface command to register h323 gateways to Call Manager, only needed the h323-gateway source address command.
But i am gettting below error whenever i put h323-gateway voip bind srcaddr X.X.X.X command under loopback interface.
Bind IP Address configured. Please remove before reconfiguring
Highlighted
Would you please upload the " sh run" from the GW.
Highlighted
The command is not need unless you have multiple interfaces.
Highlighted
answered in the other post
Highlighted
ip dhcp excluded-address 10.5.83.100 10.5.83.254
ip dhcp excluded-address 10.5.81.0 10.5.81.254
ip dhcp pool VOICE
network 10.5.82.0 255.255.254.0
default-router 10.5.83.254
option 150 ip 10.5.83.254
ip dhcp pool DATA
network 10.5.80.0 255.255.254.0
default-router 10.5.81.254
dns-server 212.76.68.200 212.76.68.201
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 10.5.83.254 255.255.254.0
ip nbar protocol-discovery
ip flow ingress
ip flow egress
h323-gateway voip bind srcaddr 10.5.83.254
interface Loopback10 ( here i want to put h323 command in order to get connected with cucm)
ip address 172.16.250.150 255.255.255.252
telephony-service
no auto-reg-ephone
max-ephones 64
max-dn 65
ip source-address 10.5.83.254 port 2000
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
Highlighted
no h323-gateway voip bind srcaddr 10.5.83.254
h323-gateway voip bind srcaddr 172.16.250.150
that's only
Highlighted
I dont want to remove that h323 bind (this is for other cme's). I want to add one more h323 in order to connect cucm.
Highlighted
this command enable you to source h323 traffic with a specific ip add
It help in defining ur security policy to this specific IP
from my understanding, you need to use the same cme as h323 gw in many cucms
so why you don't use the same ip add as h323 gw in all the cucms
Highlighted
Don't think you can not have more than one bind cmd on one GW.
