MGCP Protocol using NI1 on cisco router
Sam naik
We have configured MGCP Protocol on cisco router using PRI with NI2 switch type and working fine, but for temporarty basis we have to switchover to NI1
Is there possibililty to change the NI2 to NI1 and if yes how could we do that?
Sam
ronpatel
Level 8
Level 8
Hi Sam,
Are you using MGCP auto config for gateway configuratio or you have manually configured the MGCP gateway.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
HI Ronak,
We are using MGCP auto configuration, two lines ccm-manager config given and all config fetching from CUCM currently,
We will use two PRI  - So will it possible - one PRI NI1 and another NI2?
1 PRI - CUCM - DMS 100 NI1----------Centeral office Moetel DMS 100 NI1
i.le NI1 to NI1
and other PRI CUCM NI2 --------central office NI2=GTD 5
i.e NI2 to NI2
Thank
Sam
