Walkthrough Wednesdays
276
kiranjose
Beginner
MGCP_REGISTRATION
MGCP Gateway is not registering.Pls help me guys.
3 REPLIES 3
Aman Soi
Advisor
Hi Kiran,
You need to provide voice Gateway config along with CUCM snapshot[Deivice -gateway]
Also, provide output of commands show ccm-mananger/show version /show diag from Router.
regds,
aman
dojoy
Beginner
What is your CUCM server version..?
nikshah
Unfortunately in this forum no body can help on question like this, basic deployment scenario, traces debugs from gw what do you see show ccm manager command on go, whether cecum gw config is fine , whether the gw type is selected correctly along with correct slot for the pri cas qsig link lots of variables so the more info you provide better your chances of getting an answer
Content for Community-Ad
Spotlight Awards 2021
