MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED?
Pointbreak
Hi Team
Regarding MGCP RSIP.
Could you please explain the below.
Forced?
Graceful?
2 Accepted Solutions
Hi Manzoor,
  • “Graceful” restart method indicates that the specified endpoints will be taken out-of- service after the specified delay.
  • “Forced” restart method indicates that the specified endpoints are taken abruptly out- of-service. The established connections, if any, are lost.
  • “Restart” method indicates that service will be restored on the endpoints after the specified “restart delay,”that is, the endpoints will be in-service. The endpoints are in their clean default state and there are no connections that are currently established on the endpoints.
  • “Disconnected” method indicates that the endpoint has become disconnected and is now trying to establish connectivity. The “restart delay” specifies the number of seconds the endpoint has been disconnected. Established connections are not affected.
Manish
- Do rate helpful posts -
The timer is enabled by the following command ( there is no recommended way but its always good to have the graceful option as it will avoid call drops )
mgcp restart-delay
To select the delay value sent in the Restart in Progress (RSIP) graceful teardown, use the mgcp restart-delay command in global configuration mode. To reset to the default, use the no form of this command.
mgcp restart-delay value
no mgcp restart-delay
Syntax Description
value
Restart delay value, in seconds. Range is 0 to 600. The default is 0.
8 Replies 8
Manish Gogna
Hi Manzoor,
This is the setting for the mgcp sgcp restart notify and the mgcp sgcp disconnected notify commands (ENABLED or DISABLED).The one on your system is Disabled.
Manish
You may check the following link
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/42106-vg200-vfy.html
Explanation of Fields in show mgcp Command Output
Field Description
MGCP Admin State...Oper State The administrative and operational state of the MGCP daemon. The administrative state controls start and stop of the application using the mgcp and mgcp block-newcalls commands. The operational state controls normal MGCP operations.
MGCP call-agent The address of the call agent specified in the mgcp call-agent or call-agent command and the protocol initiated for this session.
MGCP block-newcalls The state of the mgcp block-newcalls command.
MGCP send SGCP RSIP...disconnected The setting for the mgcp sgcp restart notify and the mgcp sgcp disconnected notify commands (ENABLED or DISABLED).
MGCP quarantine mode How the quarantine buffer is to handle Simple Gateway Control Protocol (SGCP) events.
MGCP quarantine of persistent events is Whether SGCP persistent events are handled by the quarantine buffer.
MGCP dtmf-relay The setting for the mgcp dtmf-relay command.
MGCP voip modem passthrough The settings for mode, codec, and redundancy from the mgcp modem passthrough mode, mgcp modem passthrough codec, and mgcp modem passthrough voip redundancy commands.
Thanks for your mail.
What is the difference between forced and graceful. Could you please brief on that
Hi Manzoor,
Manish
Manish,
Could you please explain with an example.
Graceful” restart method indicates that the specified endpoints will be taken out-of- service after the specified delay?
Please consider  for me it is a new domain. :)
Basically a graceful restart waits for all active calls to clear normally ( like users hang up after the call is over ) and then does a restart, so it does not impact existing calls. However a forced restart will proceed irespective of any existing calls on the gateway and result in dropped calls.
Manish
Thank you,
What is the impact if below is enabled . and whre we mention the delay. Which is the recommend one
mgcp restart-delay
Syntax Description
value
