12-10-2015 08:56 PM - edited 03-17-2019 05:11 AM
Hi Microsoft Edge, CUCM and IE can access CUCM, but after login, only Micosoft Edge can work with CUCM, bot IE and Chrome cannot.
If using IE and Chrome, clicking each button of tool bar in CUCM gets no any reaction. Any one can give some suggestion? Thank you
Solved! Go to Solution.
12-10-2015 09:37 PM
What about Firefox, can you try that and see if it works.
Deepak
12-10-2015 10:27 PM
I don't think it will work regardless tweaking and adding some workaround. Since this is new browser released this year with win-10 and win-server 2016 by microsoft
Supported browser always listed in the RNE(release notes) which are supported and to work with respective version of CUCM. It may be that it has never been in the testbed and hard to find some tweak apart compatibility view etc..but still you will see some lag and error.
I would suggest to you IE, Chrome or mozilla firefox. detail you find in this thread.
https://supportforums.cisco.com/discussion/12726441/ie-can-access-cucm-chrome-cannot
Br,
Nadeem Ahmed
PS: Please rate all useful post.
12-10-2015 09:17 PM
Can you try enabling the Compatibility View and then try.
Deepak
12-10-2015 09:34 PM
Thanks for your reply. I just tried, but it still cannot work.
12-10-2015 09:37 PM
Deepak
12-10-2015 10:16 PM
Please add the hostname or the IP which ever is being used to browse in the compatibility settings page and then try again.
12-10-2015 10:27 PM
Br,
Nadeem Ahmed
