11-04-2016 05:52 AM - edited 03-17-2019 08:34 AM
Hi Team,
I tried migrating a Cisco phone 7940 SCCP to SIP and shows me the following error:
Migrate Phones - SCCP TO SIP
Begin Time: 11/04/2016 12:31:05
End Time: 04/11/2016 12:31:05
Query:
MIGRATE SCCP ALL PHONES
SET Values:
Reset phones = true
Result Summary:
MIGRATION for 0 PHONE passed.
MIGRATION for 1 PHONE failed.
Failure Details:
devicename Error Error Code Description
SEP001BD4a09027 130 Ring Settings for esta line are not supported for this device
What could be the reason?
Thanks & Regards,
Juan Miguel Huertas Alegre
Solved! Go to Solution.
11-05-2016 11:48 PM
You will continue to have that error as if you have a look at the CUCM config, there are no options for "Ring setting" for the 7940 Sip phones under the Line configuration phone.
This option is available under the 7940 SCCP phones but not under the 7940 SIP phones and thus you will have that error.
I guess for these phones you will have to add them manually instead of the migration option.
11-05-2016 11:48 PM
11-06-2016 11:51 AM
Also, I generally advise against doing this. The 7940/7960 are "Type A" phones and lack a fair amount of functionality over SIP. Case I point is they will require SIP Dial Rules.
11-08-2016 03:08 AM
Hi Team,
I migrated the phone manually and it worked correctly.
Thanks & Regards,
03-21-2019 07:57 AM
