Hello guys,
I've recently installed a CUOM server, version 8.6.
This is intended to replace an old deployment based on an old version (i think version 3, I will check and give you the correct info).
I want to move the configuration from the old server to the new one. I'm not experienced with CUOM but as far as I understood it's not possible to export the db from the old version and restore to the new one.
What other methods can i consider in order to move the config to the new environment?
Many thanks for all your replies.
Lorenz
have a look to my blog lgrconsulting.com
