156
Highlighted
Participant
Migration to CUBE and SIP
Hi all,
I will be migrating from MGCP PRI over to SIP in the coming month and was trying to find out if I can use my 3945 to do both the CUBE and the PRI gateway functions at the same time while I'm doing the migration. I can always revert to an old 2811 if needed, but was wondering if it was possible.
CUCM version is 8.6 and router IOS is 15.0(1r)M16,
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Yes.  Make sure you have
Yes.  Make sure you have proper CUBE licenses though.
2 REPLIES 2
Highlighted
Hall of Fame Master
Highlighted
Participant
I will have the license
I will have the license before I start. Thanks muchly for the answer... there may be more questions coming!
Content for Community-Ad
Cisco COVID-19 Survey
