181
Highlighted
Beginner
Migration With PCD
Is there anyway to re-run a migrate task only for subscriber after successfully migrate pub and if error occurs during sub migration?
1 ACCEPTED SOLUTION
Highlighted
Advisor
Hi , I suppose u need to
Hi ,
I suppose u need to create a new migration task with same source cluster and a new destination cluster.
regds,
aman
5 REPLIES 5
Highlighted
Advisor
Hi ,
regds,
aman
Highlighted
Beginner
I have tried to do simple
I have tried to do simple migration and failure during sub migration.
how can i my old pub and sub get back online?
shutdown new installed vm and restart old pub/sub but it doesn't work
thanks
Highlighted
Advisor
Hi, what was the earlier CUCM
what was the earlier CUCM version ?
what is the error u get when u restart old servers?
why do not you discover cluster again?
regds,
aman
Highlighted
Beginner
i will do the migration later
i will do the migration later its generating error msg.
after re-starting several time now old version work.
attached the error massage i got while migrating.
the same error i got when i migrate pub first and i have change LRO setting to 0 on both host server. but still getting error for sub.
any idea to resolve this?
Highlighted
Advisor
Hi, You can get the latest
You can get the latest logs from PCD from CLI by using command to get more details about the error
file get activelog tomcat/logs/ucmap/log4j/*
there could be a possibility that Subscriber is getting hanged.you can login through GUI into OS administtration and check the status of Install/Upgrade
regds,
aman
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
