Beginner
Minimum servers in calla manager cluster should contain
How many minimum  servers should available in CUCM cluster
2 REPLIES 2
VIP Advisor
Re: Minimum servers in calla manager cluster should contain
As always it depends. You need a minimum of 1. And 2 to make it redundant. Then you might want to add more depending on geographical spread. How big is your deployment?
Please remember to rate useful posts, by clicking on the stars below.
Hall of Fame Cisco Employee
I suggest you review the SRND on this topic.
java
if this helps, please rate
Content for Community-Ad
August's Community Spotlight Awards
