07-05-2010 11:26 AM - edited 03-15-2019 11:33 PM
hi guys!
I need information about a CDR.
I need a report of unanswered calls, and tickets are sent to my FTP these tickets does not have information on unanswered calls.
Will I need to enable some feature.
I am using CUCM 7.1.3
Solved! Go to Solution.
07-05-2010 11:51 AM
Set the "CDR Log Calls with Zero Duration Flag " to true in the Service Parameters for CallManager. This will log calls with 0 duration. then you can see those in CDR reports.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-05-2010 11:51 AM
java
07-05-2010 12:10 PM
Thanks Java
will enable, and then I'll test.
07-14-2010 10:17 AM
Ok Java is working normally!!!!!
09-16-2010 05:04 AM
I'm new in cisco call manager. I have a need for creating reports of user missed calls. I have found a guide hot to do it, but do not ger any info when report is generated.
Step 1 Choose User Reports > Cisco Unified IP Phone.
The Cisco Unified IP Phone window displays a list of all Cisco Unified IP Phone services that have been configured in the system.
Step 2 In the List of Cisco Unified IP Phone area, choose the services that you want to include in the report.
Step 3 Click the right arrow to add the chosen service to the Selected Cisco Unified IP Phone box.
The report will include all services that are listed in this box when you generate it.
maybe you can give me some advice?
Thanks..
09-16-2010 02:10 PM
I'm using Server Billing, and I enable CDR.
In the FTP server is colected by my "Server Billing".
See this docto about CDR http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/CAR.html
09-20-2010 11:44 PM
I also have CDR enabled. And i need to generate a user report for missed calls, but i get 0 in generated *.pdf file no mater if it's recieved calls or missed. I've added an ftp server, but it didn't help. Maybe you will know where's the trick here in my situation? Thanks in advance..
09-21-2010 07:56 AM
I understand,
I think you´re confused about the "missed call",but my server billing mean call with 0 duration, as missed call.
09-21-2010 11:12 PM
no you got me wrong. I am not getting any report at all, nor answered nor missed calls, the generated pdf file is empty. Maybe there is some settings i have to apply first?
Thanks..
09-22-2010 07:51 PM
The only document I can reference is to see if this helps you in something.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/car.pdf
11-18-2010 03:20 PM
I have CUCM 7.0.2 and i have activated "CDR Log Calls with Zero Duration Flag " but i didn't see calls records with Zero Duration in CDR .
Do i need to to restart CDR services or other or i missed some more configuration?
Thanks.
MC
11-20-2010 11:02 AM
how are you doing to see these calls?
I believe you do not need to do anything else for this!!
11-24-2010 03:24 AM
CDR analisys and Reporting
Menu CDR >Search user /extension
I didn't see CDR information of incoming calls from PSTN that i didn't answer.
MC
06-28-2015 07:29 AM
Hi MC,
Did you get any solution to this issue?
I have enabled "CDR Log Calls with Zero Duration Flag". Still the zero duration calls are not listed in cdr.
CUCM in question is version 7.
I am not using any billing server. I am unable to find cdr for unanswered calls while searching for cdr in CDR Administration and Reporting.
Thanks in advance.
With Kind Regards
Fahim Sha.
06-30-2015 02:27 PM
it was five years ago...but i think i didn't manage to solve that problem.
regards
Mc
