5572
Advocate
Missed call in the CDR
hi guys!
I need information about a CDR.
I  need a report of unanswered calls, and tickets are sent to my FTP these  tickets does not have information on unanswered calls.
Will I need to enable some feature.
I am using CUCM 7.1.3
Cheers
Bruno Rangel
Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
Re: Missed call in the CDR
Set the "CDR Log Calls with Zero Duration Flag " to true in the Service  Parameters for CallManager. This will log calls with 0 duration. then  you can see those in CDR reports.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
14 REPLIES 14
java
java
Advocate
Thanks  Java
will enable, and then I'll test.
Cheers
Bruno Rangel
Advocate
Ok Java is working normally!!!!!
Cheers
Bruno Rangel
Beginner
I'm new in cisco call manager. I have a need for creating reports of user missed calls. I have found a guide hot to do it, but do not ger any info when report is generated.
Step 1 Choose User Reports > Cisco Unified IP Phone.
The Cisco Unified IP Phone window displays a list of all Cisco Unified IP Phone services that have been configured in the system.
Step 2 In the List of Cisco Unified IP Phone area, choose the services that you want to include in the report.
Step 3 Click the right arrow to add the chosen service to the Selected Cisco Unified IP Phone box.
The report will include all services that are listed in this box when you generate it.
maybe you can give me some advice?
Thanks..
Advocate
I'm using Server Billing, and I enable CDR.
In the FTP server is colected by my "Server Billing".
See this docto about CDR http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/CAR.html
Cheers
Bruno Rangel
Beginner
I also have CDR enabled. And i need to generate a user report for missed calls, but i get 0 in generated *.pdf file no mater if it's recieved calls or missed. I've added an ftp server, but it didn't help. Maybe you will know where's the trick here in my situation? Thanks in advance..
Advocate
I understand,
I think you´re confused about the "missed call",but my server billing mean call with 0 duration, as missed call.
Cheers
Bruno Rangel
Highlighted
Beginner
no you got me wrong. I am not getting any report at all, nor answered nor missed calls, the generated pdf file is empty. Maybe there is some settings i have to apply first?
Thanks..
Advocate
The only document I can reference is to see if this helps you in something.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/car.pdf
Cheers
Bruno Rangel
Beginner
I have CUCM 7.0.2 and i have activated "CDR Log Calls with Zero Duration Flag " but i didn't see calls records with Zero Duration in CDR .
Do i need to to restart CDR services or other or i missed some more configuration?
Thanks.
MC
Advocate
how are you doing to see these calls?
I believe you do not need to do anything else for this!!
Cheers
Bruno Rangel
Beginner
CDR analisys and Reporting
Menu CDR >Search user /extension
I didn't see CDR information of incoming calls from PSTN that i didn't answer.
MC
Beginner
Hi MC, Did you get any
Hi MC,
Did you get any solution to this issue?
I have enabled "CDR Log Calls with Zero Duration Flag". Still the zero duration calls are not listed in cdr.
CUCM in question is version 7.
I am not using any billing server. I am unable to find cdr for unanswered calls while searching for cdr in CDR Administration and Reporting.
Thanks in advance.
With Kind Regards
Fahim Sha.
Beginner
Hi,it was five years ago..
it was five years ago...but i think i didn't manage to solve that problem.
regards
Mc
Content for Community-Ad
August's Community Spotlight Awards
