Missed call to email
I believe Missed call notification to email feature available in version 11. i read in google search that it required separate domain if we are using regular domain for voicemail to email.
please help.
Manish Gogna
Hi Firasat,
This feature is available in CUC 11.x as per the admin guide
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/11x/administration/guide/b_cucsag/b_cucsag_chapter_01011.html
However, I do not see any specifications for domain requirements.
Manish
I concur with my colleagues here, I recently implemented this feature at a customer and it works as advertised without any dependencies on domains.
i am trying to configure based on provided solution but it is giving me same error as i mentioned above.
http://www.ciscounitytools.com/Training/Connection/CUC11_0.html
Problem is, as i am using example.com domain for voicemail to email i can not use same domain for missed call to email. please see attached and advise.
i am not using unified messaging.
Jaime Valencia
You can see the procedure here, but you can use the same as you use for UM
https://youtu.be/Fvpjv82AI6E
java
if this helps, please rate
