Missing option mark as spam
iptsupport
Level 4
Level 4
Hello ,
I can't see the featue mark as spam in cisco 8851 .
version of phone sip88xx.12-8-1-0201-486
System version: 11.5.1.11900-26
any idea?
9 Replies 9
b.winter
as per release notes, this is supported in the CUCM version 11.5 SU8 and later.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/sustaining/cucm_b_readme-1151su10.html
BR
You are not on a version which support this feature. Upgrade to a version @b.winter mentioned   SU(8).
Response Signature
Hi Nithin ,
CUCM version is 12.5.1.
8851 model's don't have the spam list as a softkey . How do I enable it ?
There are many different versions of CM 12.5, could you please specify exactly what version you have and what firmware version you have on your phones?
The setting as such is controlled from here.
Response Signature
Hi Roger ,
CUCM Version  12.5.1.11900-146
8851 version
sip88xx.14-1-1-0001-125
At the device page under Product Specific Configuration Layout you should have this.
Response Signature
Roger ,
I dont have that . Does my CUCM version and 8851 firmware version supports that ?
Likely not as you do not have it. From what I know the feature as such came in the 12.7.1 firmware release for 88XX phones, but it could as well require a newer version of CM than what you have. Your version is SU1 and the latest release is SU7. I took the screenshot from 12.5SU5 CM with sip88xx.14-2-1-0001-14, so on that it does show up. I know we had it with the previous version of the phone firmware as well, sip88xx.14-1-1-0001-125, it’s the same as you have.
Response Signature
b.winter
was your question answered?
If yes, please mark a reply as a valid solution.
