243
eric.bias
Beginner
missing user with bulk import exchange unity 5.0.1
Unity version:5.0.1 UM
AD 2003 SP2
Description
we are reinstalling unity 5.0.1 due to instability.
After the new install, everythig seems to be ok except that when we are trying to made an import with bulk import exchange, the old users missing in the wizard but present in Active Directory. no problem to import users that was not imported in the precedent installation.
Does anyone have an idea?
Best Regards
4 REPLIES 4
Jaime Valencia
Hall of Fame Cisco Employee
have you tried using the bunny killer from the unity tools depot to verify they do not have unity properties??
javalenc
if this helps, please rate
java
Tanks for response
i will be try this tool as soon as possible and give you feedbak
Many thanks
Hi Eric,
Did you try the solution? I shall try it today hopefully, and update.
Thank you javalenc
Mohammad
Well, it works.
Thank you javalenc,
regards
Create
Recognize Your Peers
Content for Community-Ad
