Mitel phone not getting ip from voice vlan its getting from data vlan
Mitel phone not getting ip address from voice vlan its getting from data vlan via windows dhcp on cisco switch c9200
login as: magit
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
SW-c9200>en
Password:
SW-c9200#show ru
SW-c9200#show running-config
Building configuration...
ip routing
ip domain name nawanco.com
login on-success log
ipv6 unicast-routing
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
no destination transport-method email
no device-tracking logging theft
table-map AutoQos-4.0-Trust-Dscp-Table
default copy
table-map AutoQos-4.0-Trust-Cos-Table
default copy
license boot level network-essentials addon dna-essentials
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
memory free low-watermark processor 10055
redundancy
mode sso
lldp run
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any AutoQos-4.0-Output-Multimedia-Conf-Queue
match dscp af41 af42 af43
match cos 4
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any AutoQos-4.0-Output-Bulk-Data-Queue
match dscp af11 af12 af13
match cos 1
class-map match-any system-cpp-default
description EWLC data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any AutoQos-4.0-Output-Priority-Queue
match dscp cs4 cs5 ef
match cos 5
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any AutoQos-4.0-Output-Multimedia-Strm-Queue
match dscp af31 af32 af33
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-all AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-all AutoQoS-VoIP-Control-Trust
match ip dscp cs3 af31
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any AutoQos-4.0-Output-Trans-Data-Queue
match dscp af21 af22 af23
match cos 2
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any AutoQos-4.0-Output-Scavenger-Queue
match dscp cs1
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
class-map match-any AutoQos-4.0-Output-Control-Mgmt-Queue
match dscp cs2 cs3 cs6 cs7
match cos 3
policy-map AutoQos-4.0-Output-Policy
class AutoQos-4.0-Output-Priority-Queue
priority level 1 percent 30
class AutoQos-4.0-Output-Control-Mgmt-Queue
bandwidth remaining percent 10
queue-limit dscp cs2 percent 80
queue-limit dscp cs3 percent 90
queue-limit dscp cs6 percent 100
queue-limit dscp cs7 percent 100
queue-buffers ratio 10
class AutoQos-4.0-Output-Multimedia-Conf-Queue
class AutoQos-4.0-Output-Trans-Data-Queue
class AutoQos-4.0-Output-Bulk-Data-Queue
bandwidth remaining percent 4
class AutoQos-4.0-Output-Scavenger-Queue
class AutoQos-4.0-Output-Multimedia-Strm-Queue
class class-default
bandwidth remaining percent 25
queue-buffers ratio 25
policy-map AutoQos-4.0-Trust-Cos-Input-Policy
class class-default
set cos cos table AutoQos-4.0-Trust-Cos-Table
policy-map system-cpp-policy
policy-map AutoQos-4.0-Trust-Dscp-Input-Policy
class class-default
set dscp dscp table AutoQos-4.0-Trust-Dscp-Table
policy-map AutoQoS-Police-CiscoPhone
class AutoQoS-VoIP-RTP-Trust
set dscp ef
class AutoQoS-VoIP-Control-Trust
set dscp cs3
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address dhcp
negotiation auto
interface GigabitEthernet1/0/1 (connected to Mitel Controller as Source)
switchport access vlan 41
switchport mode access
switchport voice vlan dot1p
no cdp enable
auto qos trust dscp
spanning-tree portfast
service-policy input AutoQos-4.0-Trust-Dscp-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3 (connected to Windows DHCP Server)
switchport access vlan 40
interface GigabitEthernet1/0/4 (connected to Mitel phone 6905)
description link nawan-Mitel
switchport voice vlan 41
interface GigabitEthernet1/0/23
switchport mode trunk
interface GigabitEthernet1/0/24 ( Connected to Firewall for manage External Traffic 172.16.240.50)
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
no ip address
ipv6 address autoconfig
ipv6 enable
ipv6 nd autoconfig default-route
ipv6 dhcp client request vendor
interface Vlan40
description Data
ip address 172.16.240.9 255.255.255.0
ip helper-address 172.16.240.100
interface Vlan41
description MitelPBX
ip address 192.168.250.254 255.255.255.0
no ip route-cache
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.240.50
ip tftp source-interface Vlan1
control-plane
service-policy input system-cpp-policy
SW-c9200#
b.winter
Why are you posting this question in a Cisco Collaboration forum?
First: It has nothing to do with Cisco phones.
Second: If you have problems with your Switch / Router config, then why don't you post it in the networking forum?
Third: Have you even checked, if your 3rd party phone supports LLDP, understands the concept of "voice lan", ...? You can't just plug it in like a Cisco phone and expect everything to work the same way.
Hi @sarfarazqadry2008
 If your Mitel phone is getting IP address on the Access Vlan, why dont you send the informations it needs through the DHCP option and allow it to join your Mitel Voip system?
The Voice vlan it is a feature used for Cisco phone but may not be a requirement for Mitel  phones.
"The voice VLAN feature permits the switch ports to carry voice traffic with Layer 3 IP precedence and Layer 2 class of service (CoS) values from an IP phone. Based on IEEE 802.1p CoS, the switch supports quality of service (QoS) which uses classification and scheduling to send network traffic from the switch. You can configure the Cisco IP phone to forward traffic with an IEEE 802.1p priority, and configure the switch to trust or override the traffic priority assigned by an IP phone."
