Mixing H323 and MGCP
eric.bias
Beginner
Beginner
A customer needs to add in parallel Fax server wich T38 feature activate.
Actually we have fax passtru activate with MGCP GW due to ATA endpoint.
Does it possible to just configured on the same GW a dial-peer with T38 activate and connected fax server through this dial-peer? for PSTN, customer are going to add specific PRI for fax server.
what is the best design?
1 REPLY 1
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Yes, if you add a PRI you would be able to use it in H.323.
Personally however, I would convert everything to H.323, more features, simpler tp configure, less bugs.
