MMOH with 2 vgw
benny
Hi All..
Just a quick check, is it possible to use MMOH with 2 VGWs so that when 1 VGW goes down, my MOH is still available?
Rgds
gogasca
Level 10
Level 10
It will be possible but when up and running you will have 2 streams mixed...
Hi There..
Yah... That's wat i experienced. Rite now i can only enable one. and if it fails, i enable the other. But just wondering any other workaround without manual config.
RGds
Hi All,
I actually sort of encountered a scenerio where i'm trying to do MMOH with 2 VGW & 2 CCM. When i use subscriber as the MOH, it works fine, but the problem is when the MOH server is down, my MMOH stops. Then i have to manually enable MOH on Publisher.
Just wish to check is there a better way to do it?
