02-02-2015 10:36 PM - edited 03-17-2019 01:49 AM
I would like to verify that IM&Presence server is not required for MRA Deployment.?
Currenlty we are running jabber in phone mode with CUCM Only, we are going to extended it over the internet hence MRA.
Solved! Go to Solution.
02-05-2015 05:43 AM
02-05-2015 05:43 AM
I believe this is supported.
02-07-2015 10:26 PM
I confirmed it with TAC and as you say its supported.
Also for external jabber login without security popus, Do i also need to provided Expressway-C a public CA certificate or can I provide a local unsecured certificate.
02-07-2015 11:58 PM
Expressway C can use an enterprise CA certificate but Expressway E needs Public CA to talk to your clients
02-08-2015 12:31 AM
Thanks for the prompt response.
