Mobile Phone number error
Virstra001
    Hi ,
        currently i am facing " Mobile Phone number error" in Remote Destination profile whenver i try to send call to mobile phone.
My CUCM version is System version: 7.1.5.30000-1.
Prashant Dhotre
Anas Abueideh
Level 9
Level 9
make sure your mobile number matches route pattern
Anas
please don't forget to rate the helpful posts
Yes route pattern matches with Remote destination number.
Prashant Dhotre
did you assign the appropriate calling search space under the remote destination profile config
Anas
That screenshot is inaccurate. For Mobile Connect call forking the Rerouting CSS must be set to a value that can dial the Remote Destination. The normal CSS is only used for Mobile Voice Access calls into CUCM.
Please remember to rate helpful responses and identify helpful or correct answers.
