04-09-2013 02:39 AM - edited 03-16-2019 04:41 PM
Hi ,
currently i am facing " Mobile Phone number error" in Remote Destination profile whenver i try to send call to mobile phone.
My CUCM version is System version: 7.1.5.30000-1.
Prashant Dhotre
04-09-2013 03:28 AM
make sure your mobile number matches route pattern
Anas
please don't forget to rate the helpful posts
04-09-2013 03:31 AM
Yes route pattern matches with Remote destination number.
Prashant Dhotre
04-09-2013 03:45 AM
did you assign the appropriate calling search space under the remote destination profile config
Anas
04-14-2013 08:59 AM
That screenshot is inaccurate. For Mobile Connect call forking the Rerouting CSS must be set to a value that can dial the Remote Destination. The normal CSS is only used for Mobile Voice Access calls into CUCM.
Please remember to rate helpful responses and identify helpful or correct answers.
