Highlighted
Beginner
Modify a sip invite
We have a sip invite coming from Lync with the first name and the last name. The call is being denied by the ITSP because they need a DID in the from field.
From: <sip:glenn.orcutt@1.1.1.1>;tag=1207269~b2e7ab81-19a9-49f9-adaf-eb693f51e143-47259121
what i would like to do is replace "glenn.orcutt" with "1111111111". I cannot use a blanket replace all header. I was trying to find out if there is a way to match the character "." (dot) in the sip profile
4 REPLIES 4
Hi Amit.Where do you need to
Hi Amit.
Where do you need to modify the invite message?
On a Cube or CUCM?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Beginner
On the CUBE, sorry forgot to
On the CUBE, sorry forgot to mention that.
Hi Amit Create voice class
Hi Amit
Create voice class sip profile such as
voice class sip-profiles 100
 request INVITE sip-header From modify "\"(.*)\" <sip:(.*)@(.*)>" "\"\" <sip:1111111111@1.1.1.1>"
add that profile to outgoing dialpeer to lync
dial-peer voice 10 voip
voice-class sip profiles 100
Carlo
Beginner
I was able to use this script
I was able to use this script and make it work
request INVITE sip-header From modify "<sip:[a-z]+\.[a-z]+@" "<sip:1111111111@"
tested it at
http://sip-profile.54.227.241.219.xip.io/
Content for Community-Ad
August's Community Spotlight Awards
